1997 Ram 2500 5.9 gas wont start with aftermarket tach #1474759
07/27/13 09:02 AM
07/27/13 09:02 AM
Jacksonville, AR
dmckeehan Offline OP
Jacksonville, AR
Got a 1997 Ram 2500 with 5.9 gas motor. truck starts and runs fine without Autometer Sport Comp tach hooked up. Hook tach up to signal wire on coil, truck wont start. unhook wire to coil, truck fires right up. Any suggestions what this might be?
Thanks for the help!
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
Re: 1997 Ram 2500 5.9 gas wont start with aftermarket tach [Re: dmckeehan] #1474760
07/27/13 01:00 PM
07/27/13 01:00 PM
NJ
rth Offline
rth  Offline
NJ
The tach should be on the neg side of coil. If it is maybe tach shorted out.
Re: 1997 Ram 2500 5.9 gas wont start with aftermarket tach [Re: rth] #1474761
07/28/13 03:57 AM
07/28/13 03:57 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
with the tach hooked up and motor not starting,, crank the starter and watch the tach,,,if you can see the light bulb in the tach plusating when its cranking there is a short in the tach and it will not start,,, ive had an auto meter and a stewart warner tach both do the same thing resulting in a no start,,just my experience,,good luck,,, call auto meter ask if that is a warranty issue
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
