1969 Plymouth temp gauge (Help wiring gurus) #1474700
07/27/13 01:16 AM
07/27/13 01:16 AM
New Berlin,Wi
Firepowerflyer Offline OP
New Berlin,Wi
Hey gang I'm working the bugs out of my almost completed resto on my 69 GTX.I have a temp gauge that does not seem to do anything. I had the whole cluster restored years ago by one of the bigger gauge companies but I don't remember who anymore. Anyway brand new M&H harness through out entire car. Everything else seems to be working great. I know there's a way to test sending unit with test light, not sure how. What's my next move replace sending unit? How do I go about checking the gauge? I hope I don't have to pull the cluster(pain in the butt)I did make sure the main connector was tight.
Joe
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474701
07/27/13 07:30 PM
07/27/13 07:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have the original instrument cluster voltage regulator installed, with the temperature sender wire connected, use a test light from ground to the sending unit terminal. The light should be flashing.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: 6PakBee] #1474702
07/31/13 05:30 PM
07/31/13 05:30 PM
New Berlin,Wi
New Berlin,Wi
Ok I did the following and I have no flashing light at the sending unit when the wire is hooked up.Do I have a dead gauge?How do I test the gauge or could it be a bad sender?
Thanks in advance
Joe
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474703
07/31/13 07:07 PM
07/31/13 07:07 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Thanks in advance
Could be a bad inst cluster voltage reg. Maybe bad connection at the bulkhead connector.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: pushbutton] #1474704
07/31/13 07:36 PM
07/31/13 07:36 PM
New Berlin,Wi
New Berlin,Wi
I thought if the instrument voltage reg was bad some of the other gauges would not read correct? Everything works perfect except temp gauge dose not move.I've checked all connections already all seem good and tight,I know the connections are clean,it's all brand new.
Joe
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474705
07/31/13 08:01 PM
07/31/13 08:01 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Disconnect the violet wire at the temp sending unit and connect it to vehicle ground. Turn the ignition switch to the "On" position, the cluster gauge, if operating correctly, with indicate "full" hot. This test procedure works the same for the fuel and oil gauges as well.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: 1970_EK2AAR] #1474706
07/31/13 09:40 PM
07/31/13 09:40 PM
New Berlin,Wi
New Berlin,Wi
Ok I grounded out the sending unit wire and turned key on and the temp gauge still does not move,stuck on cold. For what it's worth I took a test light to back of temp gauge and one side has a blinking light the other side of gauge has nothing? Bad gauge?
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474707
07/31/13 09:50 PM
07/31/13 09:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Don't call it a bad gauge just yet...The blinking light means your voltage limiter is working and supplying current......Make sure you have a good connection between the bulkhead terminals for the sending unit wire... If that checks out then you can test the gauge and see if you have a range of motion...
Disconnect the gauge from the cluster wiring and use 2 C or D batteries to get 3 volts...Then connect it to the gauge{pos to limiter post,neg to sender post}...If it's good it should come up to about half way or a little better with the sweep...
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: screamindriver] #1474708
07/31/13 10:20 PM
07/31/13 10:20 PM
New Berlin,Wi
New Berlin,Wi
Ok do I need to pull the gauge out of the cluster? If so does the whole cluster have to come out of the dash to get the gauge out? It's been a couple of years since I put it together. Could I leave the gauge in place and disconnect the battery and put alligator clips on the gauge posts and hook it up to the D or C batteries like you explained?
Joe
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474709
07/31/13 10:26 PM
07/31/13 10:26 PM
Kirkland, Washington
Pacnorthcuda Offline
Joe
No! screaming is right. You just have to have access to the terminals. Juggling two 1.5 volt batteries can be a pain. Even ONE battery will cause the gauge to move if the gauge isn't dead.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Pacnorthcuda] #1474710
07/31/13 11:48 PM
07/31/13 11:48 PM
New Berlin,Wi
New Berlin,Wi
I think my gauge is DOA So I taped two D batteries together and checked it with a test light which was dim so I know I had them together good.I ran two leads two the gauge posts and hooked them to the batteries,NO movement at all. So what all do I have to tear apart to get my gauge out?
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474711
08/01/13 08:05 AM
08/01/13 08:05 AM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Unfortunately the cluster assembly must be removed from the dash frame in order to remove the gauge. Whether a base set-up or Rally, the removal process is the same. Once the instrument cluster module is on the bench, the trim is removed, the push pins lifted and the clear lens is separated. Now remove the gauge stem nuts from the circuit board connection and the individual gauge is finally in your hands.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: 1970_EK2AAR] #1474712
08/01/13 11:17 AM
08/01/13 11:17 AM
New Berlin,Wi
New Berlin,Wi
Ok thats what I figured would need to be done.One last idea on this matter,does it matter which side the two wires on the back of the gauge go?? Could I have the wires switched on the gauge itself??
Thanks for the help
Joe
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474713
08/01/13 02:34 PM
08/01/13 02:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks for the help
Joe
yes it will matter .
Have you used your meter to confirm continunity between the sending unit end of the wire and the other end under the dash ? This wouldn't be the first time an M+H harness had a crossed wire.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: JohnRR] #1474714
08/01/13 05:33 PM
08/01/13 05:33 PM
New Berlin,Wi
New Berlin,Wi
John I do not have my multi meter home at this time,just a test light.I can grab one and check from under the dash to sending unit to make sure I'm good there. Can you tell me which color wire goes to what side of gauge,or what side of the gauge should be blinking.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474715
08/01/13 06:10 PM
08/01/13 06:10 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Setting in the drivers seat the right side stud should blink. If it's crossed under the dash it would be in the multi pin connector. The cluster I looked at was a 68 but I would think they would be the same.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: pushbutton] #1474716
08/05/13 10:05 PM
08/05/13 10:05 PM
New Berlin,Wi
New Berlin,Wi
I checked what side of my gauge is blinking and sitting in the driver seat the right side post is blinking. I have not check continuity all the way to the sender yet, I double checked all the connections. I looked at the schematic and the multi pin connector appears to wired correctly. I'm leaning towards a bad gauge unless I'm missing something.
Re: 1969 Plymouth temp gauge (Help wiring gurus) [Re: Firepowerflyer] #1474717
08/05/13 10:21 PM
08/05/13 10:21 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Check to make sure the sending unit is getting a ground. Not too much thread sealing compound Teflon tape or paint in the threads.
