Re: Relocating springs on an early A-body....pics?
[Re: mopowers]
#1474441
07/26/13 06:31 PM
07/26/13 06:31 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Go here... http://www.reillymotorsports.com/store/home.php?cat=276Buy only the boxes as the rest of the stuff is cheap and relatively easy to get unless going sliders. The rear you have to make sure you get proper shackle angle. That can be a chore sometimes. If you are using the current springs and the rear shackle angle is correct, pass the tube through the frame in same approximate location. I'd reuse the old shackle if in good shape and get some urethane bushings. There is one pic of the boxes installed by pettybluedart on FABO, IIRC. Not a great pic. As Mopowers mentions, same install process as any other 67-76 A body.
[Re: dustergirl340]
#1474443
07/26/13 08:34 PM
07/26/13 08:34 PM
Posts: 10,031 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My 65 Dart,,,,,I set the rear back a 1/2 inch for extra tire clearance at the front lip. This may get real close to the fuel tank, it did with the 8.8 rear I put in. Be sure and go as high as you can with the top holes, otherwise the stance with SS springs will be very high. I put two inch lowering blocks on this car to get a decent stance with 3400 lb SS springs. The next lighter set of springs may drop the stance somewhat, certainly wouldn't hurt the ride. Mine is a bit stiff.
[Re: gregsdart]
#1474444
07/26/13 08:51 PM
07/26/13 08:51 PM
gregsdart
I got this kit from Mancinis. You need to drill your own holes. Having them perfectly square in the car is extremely important. I didn't do it, but a 1/2 inch rod long enough to go through both relocating boxes would help with proper placement.
[Re: gregsdart]
#1474446
07/26/13 08:57 PM
07/26/13 08:57 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I did it the hard way with my '65. What I later learned was to use the stock front spring mounts to locate your holes on the new inboard spring mounts. Get the boxes welded in , then bolt up the stock mounts and use a 5/8" transfer punch ( Maybe it was 1/2 " with the stock mount , I don't remember now )to mark the original holes. Then measure and move from that point.... or use them if you want that location. I used plumb bobs from the torsion bar cross member and projected spring mount hole center line.....measured four or five times and drilled once. LOL I went back 3/4" with the axle , and with the housing braced it gets close , but still fits with the stock tank. I also had the housing narrowed 2" per side and can fit a 295 - 55 X 15 on a 15 X 10 with a 6.5" back space. This fits comfortably and I could possibly squeeze more in there , but not a 315 I don't think. I used sliders on the back , but a block to move the shackle mount will get the geometry ironed out easy enough.
[Re: tubtar]
#1474447
07/26/13 09:05 PM
07/26/13 09:05 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Big Block Dart site has a whole feature in the tech section.Some pretty good pictures with some good instructions.One of the best is to weld a large washer on the rear frame tube to reinforce it.Dont know how much room you need but they have a 1/2 inch shackle kit to move them also.Rocky
Chrysler Firepower
[Re: therocks]
#1474448
07/26/13 09:14 PM
07/26/13 09:14 PM
RobX4406
Here's how I get mine in and level. RMS boxes are already drilled so it should be easy to install. Level car, cut a front hanger in half, use a 1/2 or 5/8" bar spanning the width. Level the bar and shim each hanger as necessary to get it square. ![](http://img.photobucket.com/albums/v655/crackedback/Relo/Picture003.jpg)
[Re: RobX4406]
#1474449
07/26/13 10:25 PM
07/26/13 10:25 PM
tubtar
St. Paul , Mn.
I tried finding pics of this Rob......I thought the bar was a great idea but couldn't figure out how to explain it. using the original hangers for line up is certainly gonna get you factory close. ![](/ubbthreads/images/graemlins/thumbs.gif)
