Torison Bar ? #1474334
07/26/13 09:51 AM
07/26/13 09:51 AM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
I installed small block torsion bars on my 69 roadrunner ,to get ride height the driver side adjuster is maxed out and pass. side is backed way out and I still don't have the height I want.
When I installed the driver's side bar I had to pry on adjuster to get bar in. What do I have going on. Thanks for any help EDDIE B
Re: Torison Bar ? [Re: EDDIEB] #1474335
07/26/13 10:45 AM
07/26/13 10:45 AM
very likely need to reclock the hex one more 1/6 th of a turn by moving the LCA before installing the bar
