Removing the Dowel Pin from Steering Coupler
#1474297
07/26/13 01:45 AM
07/26/13 01:45 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
How the heck do you do it with the steering shaft in the coupler. I can't figure out how to leverage it with so little clearance. Tried grinding the head and pounding it through. Bad idea. it must be tapered because it aint budging and I don't want to ruin my coupling.
HELP!!!
I’m listening.
Re: Removing the Dowel Pin from Steering Coupler
[Re: buildanother]
#1474302
07/26/13 09:06 AM
07/26/13 09:06 AM
Challenger 1
Cincinnati, Ohio
It usually come out one direction a little easier than the other. And if I recall, the 5/16" drift punch is a little on the fat side and might jam itself in there once the pin is out.
It'll come out either side, it does not matter. And a roll pin punch won't get stuck. Here's what a roll pin punch looks like. And 5/16" is the exact size and you can not use any other size.
[Re: Big Bad Bee]
#1474304
07/26/13 09:53 AM
07/26/13 09:53 AM
Posts: 5,447 So Cal
Sinitro
So Cal
HELP!!!
Get the rite tool, <$20..
http://www.custommachinecomponents.com/shopdisplayproducts.asp?page=3&id=8
Just my $0.02...
[Re: 5spdcuda]
#1474312
07/26/13 06:16 PM
07/26/13 06:16 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
or simply drill it out and thread the coupler body for a machine screw. I said sheet metal screw earlier, but if you use a tap to thread the coupler body a machine screw with blue locktite would be best.
I like this idea...
What's the job of this little pin anyway?
[Re: buildanother]
#1474316
07/26/13 06:42 PM
07/26/13 06:42 PM
Challenger 1
Cincinnati, Ohio
As stated, I've always been able to squeeze that little pin out with jaws on decent channel locks and about a 5/16" nut on outer side so it can be driven through the center of the nut. It can stay there until re-assembly(if you use the coupler body over), then do the reverse with the channel locks and nut deal. Works flawlessly.
This!! I use a channel lock only also to push that little pin out enough to get it apart. No need to drill anything.
