Page 2 of 4 1 2 3 4
Re: Picking Old Geezers Brains [Re: Mike P] #1474224
08/05/13 12:51 AM
08/05/13 12:51 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
I hear you about the Overdrive Norm. I’m running the Chrysler 833 4 Speed OD in 57 Plymouth and love it. If I ever went back to an automatic, I think I would use the 518 automatic OD. I think the Imperial Owners club was making a conversion that would allow the transmission to use the original pushbutton shifter which would be a sweet setup. The nice thing is the 518 will use the same adaptor the 727 does.
Getting the “right” wheels for these can be a challenge. JMO but most modern wheels just don’t look right on these cars. The ones I ran on the Gold and white 57 were actually mid 70’s Chrysler road wheels that I modified to use original 57 Dog Dish caps on. If I were to change oner to different wheels I think I would probably go with the Torque Thrust Ds (the mag with a dark center.
As far as AC I took the easy way out on both my Dodge and Plymouth and used era correct under dash units. They work great and I think look appropriate to the car.
By the way the dash on the 57 Dodges lend themselves really well to a 2 tone paint scheme that matches the body color.
If you can’t tell I’m looking forward to watching your progress on the car. LOL.
imperial services make an adapter to use push buttons with a non push button 727
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Picking Old Geezers Brains [Re: fstfish66] #1474225
08/06/13 12:52 PM
08/06/13 12:52 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
I really appreciate all the great info you guys have given me. As time permits I am trying to put together a good game plan for the resto of this car. I definitely want it to look like a period correct hot rod on the outside but also want all the modern comforts within reason. I should have the car at my shop sometime next week. After a good cleaning I will see if I can figure out how to post more pics.
Re: Picking Old Geezers Brains [Re: Norm] #1474226
08/17/13 04:47 PM
08/17/13 04:47 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
I still don't have the car at my shop yet but it won't be long. The 392 hemi I had lined up is no longer available. Don't ask. I know of another 392 that's in a late 50's 2 1/2 ton farm truck that runs perfect but the farmer won't get rid of it. I don't blame him. My car has the 325 poly head engine and from what I read the block will also accept hemi heads. Of course the pistons, valve gear, pushrods, etc. would also have to be changed. Is this true? If so which hemi heads and manifolds will work? I just want a hemi under the hood!
Re: Picking Old Geezers Brains [Re: Norm] #1474227
08/17/13 08:35 PM
08/17/13 08:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dodge Hemi parts are used, not Chrysler, not Desoto.
http://www.hothemiheads.com/hemi_info/hemi_engine_id.html
Don't be the exception.
Re: Picking Old Geezers Brains [Re: Supercuda] #1474228
08/18/13 01:18 PM
08/18/13 01:18 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
So you are saying that hemi parts that came in a Dodge(241, 270, 315, 325) are the only parts that will possibly fit a 58 325 engine. I know that Chrysler and Desoto hemi's are different cubic inches than a Dodge but figured the heads and intake manifolds were interchangeable. If not what were they thinking back then. Oh well, the search is still on! Thanks for the info!
Re: Picking Old Geezers Brains [Re: Norm] #1474229
08/18/13 03:51 PM
08/18/13 03:51 PM
Almost nothing interchanges between Dodge, DeSoto and Chrysler early Hemis. (But some 55-6 Plymouths and some low-line 57 DeSotos used Dodge poly engines.) What were they thinking? Probably copying General Motors, because at that time each GM make designed and built its own engines. Chrysler saw the light by the late 50's; GM finally woke up a couple decades later.
Bore center-to-center distance for the three Mopar early hemi engine families are:
Dodge: 4.1875
DeSoto: 4.3125
Chrysler: 4.5625
Obviously, with cylinders a different distance apart, heads, intake manifolds and cranks cannot interchange. There are also low deck and raised deck versions of the Dodge and DeSoto hemis, and raised port head versions of the Chrysler hemis, so intake manifolds don't all interchange even within the three engine families.
Re: Picking Old Geezers Brains [Re: Norm] #1474230
08/18/13 06:38 PM
08/18/13 06:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Correct. Who knows why Chrysler did that when their flathead 6's were pretty much the same across the board.
Re: Picking Old Geezers Brains [Re: Supercuda] #1474231
08/18/13 06:47 PM
08/18/13 06:47 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
Well I see why the Chrysler 354 and 392 hemi's are the engines of choice. No wonder they are hard to find! Thanks again for the info!
Re: Picking Old Geezers Brains [Re: Norm] #1474232
08/19/13 03:00 PM
08/19/13 03:00 PM
dogdays Offline
dogdays  Offline
Let's not forget the A engine poly, 4.46" bore spacing, which made it all the way to present, IIRC.
There is no reason why a 5.7 wouldn't do the trick. It won't cost any more by the timr you get done buying all those expensive Firepower parts, and it weighs nearly 300 lb less.
R.
(just turned 59 which makes me a geezer, too!)
Re: Picking Old Geezers Brains [Re: Norm] #1474233
08/19/13 03:14 PM
08/19/13 03:14 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
norm,, sorry to hear you lost the 392..it is true the early dodge,desoto ,chrysler poly motors not the 318 poly are the same block as the hemi,,parts from dodge or desoto or chrysler do not inter change,,except for the dizzy in a few,, you will need the hemi heads and pistons to convert the poly to the hemi,,you can get pistons at egge machine shop,,,new,,, you will need to find a set of heads,,start diging the internet,,,E BAY,,, or join the hot heads forum they have a question,,,and classified section for parts,,www,hothemiheads.com a guy calls him self TRWATERS deals with the early hemis,,he is on this site also,,,i do not know if the intake from the poly will fit the hemi heads,,you would like to think it would,,,if it does,,,and if your intake is a 2 bbl,,, trwaters does a conversion on the cast iron intake from 2 to 4 bbl,, if its a dodge or chrysler hemi intakes are available new aluminum and affordable,,, for the 325 dodge u lucky dog,,,it is the same deck height as the 315 dodge,, i dont know if the valves are bigger from the 315 to the 325, a set of 315 heads can be machined to take the bigger valves if you fine a set of those,,, happy hunting,, and get out your credit card,,,,,
2015 cherokee
2013 R/T classic
Re: Picking Old Geezers Brains [Re: Norm] #1474234
08/19/13 03:18 PM
08/19/13 03:18 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
yes what were they thinking,,, that is why the early hemi program ended back then too many differnt parts made it to costly,,so they ended it till 1964 when they put a set of hemi heads on the 426 max wedge motors,,,and said here we come,,,,,
2015 cherokee
2013 R/T classic
Re: Picking Old Geezers Brains [Re: dogdays] #1474235
08/19/13 03:22 PM
08/19/13 03:22 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
R.
very true the modern hemi will cost less if you buy it right,,, but nothing has the eye candy or bling as an early hemi,,,
2015 cherokee
2013 R/T classic
Re: Picking Old Geezers Brains [Re: fstfish66] #1474236
08/19/13 04:00 PM
08/19/13 04:00 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
Exactly! Nothing has the eye candy or bling as an early hemi. The 325 in my 58 Dodge is a factory four barrel and came with dual exhaust. If I can find all the parts necessary for the hemi conversion I will take that route. I prefer a 392 and have not given up on one yet. If I put a 5.7 in then it will be fuel injected not carburetor.
Re: Picking Old Geezers Brains [Re: Norm] #1474237
08/20/13 02:08 AM
08/20/13 02:08 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
NORM, not a thing wrong with a 325 dodge,,very sought after motor,,if u look u will find a set of heads they are out there,,cant imagine why no one is re popping heads wit hall the motors out there in hot rods,,rat rods etc,,,some one is gona read this and say WTH,,, if i remember correctly,,if you look in a motor manual book that shows the hemi and poly horse power,,,the poly weighs less and i think puts out a little bit more HP compared to the hemi,,mind boggling i know,, i may have to look in my book and pritn the page,,i know my memory isnt that bad yet,,but the HEMI just has the koool looks,,,and can be made to put out more then stated..if u have a big bank account,,,lol
2015 cherokee
2013 R/T classic
Re: Picking Old Geezers Brains [Re: fstfish66] #1474238
08/20/13 12:19 PM
08/20/13 12:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://sanantonio.craigslist.org/pts/3952373980.html
50's Dodge Hemi, not mine and kinda pricey, imo.
Re: Picking Old Geezers Brains [Re: fstfish66] #1474239
08/20/13 12:22 PM
08/20/13 12:22 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
Whatever engine I end up with it will get a complete rebuild. I have drag raced on and off my entire life and have built many race engines for myself and others. This engine will get whatever machine work is needed including balancing. My point is if I'm going to spend that kind of money then I'm going to be very picky on which engine I use. I want a 392 and probably won't be happy with anything else, but................!
Re: Picking Old Geezers Brains [Re: Supercuda] #1474240
08/20/13 12:39 PM
08/20/13 12:39 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
Kinda pricey is right. I would not pay that for a 392 completely rebuilt. In my mind nobody can build an engine better than me! I'm a perfectionist and cover every detail. Machine work is just that, machine work. Find an excellent race type machine shop with a good reputation and stick with them. I understand that early hemi parts are expensive but no more expensive than race parts are. I have multiple engines that I can use including a complete 5.7 hemi with trans and all wiring with only 700 original miles. That would be neat as hell in my car but to me just would not look right. I'm not totally against it though!
Re: Picking Old Geezers Brains [Re: Norm] #1474241
08/20/13 12:41 PM
08/20/13 12:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Couple of 392's, again, I know nothing about them.
http://lubbock.craigslist.org/pts/3931110391.html
Again, kinda pricey, imo. For me, I'd just put a new Hemi in for these prices.
Re: Picking Old Geezers Brains [Re: Supercuda] #1474242
08/20/13 01:18 PM
08/20/13 01:18 PM
Fitzgerald, GA.
N
Norm Offline OP
Norm  Offline OP
N
Fitzgerald, GA.
I hope he means $2500 each which is still too high for a rebuildable core engine. On top of that they are 1138 miles from me according to mapquest. That's over $1,000 shipping one way and would cost me $600 - $700 if I went after them including motel and eats. The 5.7 is sounding better and better!
Re: Picking Old Geezers Brains [Re: Norm] #1474243
08/20/13 02:00 PM
08/20/13 02:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You could always see what Craigslist has around you. There was a disassembled 354 for $1600 in the list, but since you wanted a 392 I didn't post a link.
http://sanantonio.craigslist.org/pts/3931531238.html
Posted July 12 so I dunno if it;s still available, but at least it'll give you an idea as to what people are asking.
Page 2 of 4 1 2 3 4
