Re: Picking Old Geezers Brains
[Re: poorboy]
#1474206
07/25/13 11:04 PM
07/25/13 11:04 PM
Posts: 55 Fitzgerald, GA.
Norm
Fitzgerald, GA.
Very BIG cars! I'm pretty much an A-body guy so they are HUGE to me! I really don't want to correctly restore this car as I always have to HotRod anything I work on. I'm thinking this is a pretty rare car and should be restored correctly. I have access to a 58 392 Hemi so you know it's going under the hood after a good rebuild. I don't plan to cut or alter the body or frame in any way and keep all the original parts/pieces. I will check for frame rot everywhere. Thanks for the info Gene!
[Re: Norm]
#1474207
07/27/13 12:39 AM
07/27/13 12:39 AM
Posts: 10,589 Freeport IL USA
poorboy
Freeport IL USA
My view on restored cars is this: If your concerned about the originality of an old car, keep all the stuff you change for the future. Then fix it up and enjoy it. As long as you don't cut it up too bad, it can always be returned to its original format. I suspect that unless this is a super complete and original car, the number of people that are going to be looking for a restored version of this particular car would be relatively low, and they would be expecting to have to restore it themselves. Most buyers want something they can get in and drive. I vote to build the hot rod, and keep the original stuff you upgraded from for the next guy. Gene
[Re: poorboy]
#1474208
07/27/13 01:33 AM
07/27/13 01:33 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
GREAT FIND,,,,, lets see some pics thjey have a great roof line,,, 325 hemi or poly??
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Norm]
#1474210
07/27/13 03:55 PM
07/27/13 03:55 PM
Posts: 1,513 AZ
Mike P
AZ
Norn, sounds like a good find and nice plan for it.
I've built a couple of 57s (a Dodge and a Plymouth) for myself and worked on several other 57/58s. The 392 is a close to a bolt in as you can get. Just use the 325 Motor Mounts that are currently on the car. Electrically everything should be in the same place so that should all connect bact up. The 392 will bolt to the cast iron torqueflite that's in the car and it should last unless you get really spirited with your driving. AAJ makes a nice front Disc brake conversion that uses the stock spindles and I believe they also have a rear disc kit that reatins the stock splined axles.
I've always just run a front sway bar on mine and was lucky enough to find a couple of 58 Imperials to use as donors.
Properly done the 392 should actually add value to the car over the stock 325.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: Norm]
#1474212
07/27/13 09:00 PM
07/27/13 09:00 PM
Posts: 1,513 AZ
Mike P
AZ
Assuming the Torqueflite is in good shape to begin with it’s not quite as strong as the aluminum units but it will take a fair share of abuse especially if you keep the tie size reasonable. The biggest problem is that while standard rebuild parts are around there is no aftermarket support for things like shift kits or stall convertors (but if you feel you need those parts you will probably want to upgrade to an aluminum unit anyway. The pushbutton TFs (both the Cast Iron and aluminum) are actually shifted by a cable. The only linkage will be the kickdown and it is a pretty straight forward hookup to the later transmission if you want to go that way. I don’t really remember on the speedometer cable as I always replaced the cable and housing with a new one anyway. You will find the emergency brake is a drum mounted on the back of the transmission and it uses a trunion joint instead of a U Joint. My experience is these are just as strong as a U Joint and at least a while back rebuild kits were still available. Most of the 1962-1964 pushbutton TFs were also trunion Joints but without the emergency brake. Personally rather than go thru the driveshaft changes that would be needed, I would try to find a 1965 (one year only) TF. The 65 TF uses a conventional slip yolk making building a drive shaft a lot easier. Though this was a column shift transmission, the shifter actually still operated a cable. The problem is the valve body shifted just the opposite of the pushbutton units and would require a VB change to one from a 62-64 unit to make it work with the cars original pushbuttons. The rear end under the car is already a 8 ¼ the only thing odd ball about it is the tapered axels for the rear brake drums and like I said I think a disc brake conversion is available for it. Finally you will also need to modify the rear crossmember as the transmission mount is different between the aluminum and cast iron TFs. If the Cast Iron TF will work for you I think you are going to find using it along with the stock emergency brake and converting the existing rear end to disk is really the best way to go. As far as tires about as big as you can fit comfortably in back will be a 235/70/15 without doing any frame or inner fender mods. As far as front brakes, I was converting these cars to front Disc long before any kits were available. I’ve used both mid 70’s C Body 11 ¾” and the smaller A body units. The C Body conversion required changing to the large ball joints and spindle modifications. Both the A and C Body conversions required trimming the wheel stops and shortening the tie rod ends and tie rod sleeves to make them work. The AAJ kit is bolt on and uses the original spindle so no other mods are necessary. Personally I would never go back to converting A or C body brakes to one of these cars again. If you want to I can walk you thru the steps necessary if you want. If the car has power brakes which will be the bellows style booster, you could continue to use it, but I think you will be stuck with the single pot reservoir. My cars are manual brakes using a newer dual reservoir master cylinder and I personally don’t find it causes any excessive pedal pressure to operate them. If you get in a bind on finding a rear bumper give me a holler I might be able to dig one up. For grins here’s a picture of 57 Coronet I did several years ago (dual quad 440 with a 64 PB Torqueflite, 9 ¼” rear end and C Body Discs. And my current 57 Plymouth (Tri Power 354 Hemi, 833 Overdive 4 speed, 9 ¼” with 4.10 gears and AAJ front Disc brakes)
[Re: Norm]
#1474214
07/28/13 08:06 AM
07/28/13 08:06 AM
Posts: 1,513 AZ
Mike P
AZ
Hi again Norm, I had a couple of other thoughts when I woke up this morning and thought I’d type them up while I still remember them. On the AAJ disc brake kit I think you will find it cheaper to buy just the basic kit (brackets and bearing adaptor) and then source the rest of the parts you need locally….they provide a parts list. Then there is the steering gear. Most of the ones I’ve come across that have many miles on them have some slop in them and they are an odd ball unit and a real pain to remove. There is actually a huge plate in the drivers floor board that has to be removed and the steering gear and column have to come out thru it as a unit. I would strongly suggest that if there is any question about the gear, remove it and have it rebuilt while you y have the engine out. There are several options for upgrading the ignition. The 392 has a unique length distributor shaft, and there are aftermarket distributors available along with an adaptor to use a later model unit. I personally prefer to use stock Chrysler parts, and all that is required to convert the original distributor to electronic is to change out the upper shaft, breaker plate and pickup and vacuum advance from a 318 electronic. One new hole will have to be drilled, but that’s minor. When you rebuild the HEMI, (Hot Hemi heads will probably be your new best friend for a while LOL), you will probably want to convert the oil system over to a full flow set up and a spin on filter. Hot Heads has three adaptors, and unless you really want to use an remote set up, the one you will need to fit the body will be the one the places the filter upside down like the original oil filter is indexed. A few years ago I was hearing horror stories about the modified oil pumps Hot Heads was selling, so you might want to research that before you make a decision on a new pump. I was able to get stock type replacements for the last 2 HEMIs I rebuilt so I have no firsthand experience with the Hot Heads units. For what it’s worth, here a picture of the modified cross member (it’s from the 4 speed in my Plymouth but it would be the same mods for a TF). Basically the mount portion of a donor cross member was grafted to the original crossmember. The last thing I can think of is valve covers. I ordered about the tallest set I could find. They just barely clear the master cylinder, and this is on a short deck 354. This particular style would probably not work with your taller deck 392.
[Re: Norm]
#1474216
07/30/13 09:47 PM
07/30/13 09:47 PM
Norm
Fitzgerald, GA.
Finally got my daughter to post this pic. Can only get 1 picture to load. I recently upgraded to a smart phone and found out how dumb I really am. Car is already in the tear down stage and these are the best pics I could get. The car is positively a spring edition.
[Re: Mike P]
#1474218
07/31/13 06:44 PM
07/31/13 06:44 PM
Posts: 2,129 Vermont
TrWaters
Vermont
The small block distributor is a drop in for the Dodge low deck early hemis. All others require a longer shaft. Melling has reintroduced the M-50 oil pump used in 392 hemis, so no need to fool with adapters. Hot Heads has a lot of parts, but they are not the only ones. www.trwaters.com has a few items, as do others.
[Re: Norm]
#1474220
08/03/13 02:33 PM
08/03/13 02:33 PM
Posts: 1,513 AZ
Mike P
AZ
I hear you about the Overdrive Norm. I’m running the Chrysler 833 4 Speed OD in 57 Plymouth and love it. If I ever went back to an automatic, I think I would use the 518 automatic OD. I think the Imperial Owners club was making a conversion that would allow the transmission to use the original pushbutton shifter which would be a sweet setup. The nice thing is the 518 will use the same adaptor the 727 does.
Getting the “right” wheels for these can be a challenge. JMO but most modern wheels just don’t look right on these cars. The ones I ran on the Gold and white 57 were actually mid 70’s Chrysler road wheels that I modified to use original 57 Dog Dish caps on. If I were to change oner to different wheels I think I would probably go with the Torque Thrust Ds (the mag with a dark center.
As far as AC I took the easy way out on both my Dodge and Plymouth and used era correct under dash units. They work great and I think look appropriate to the car.
By the way the dash on the 57 Dodges lend themselves really well to a 2 tone paint scheme that matches the body color.
If you can’t tell I’m looking forward to watching your progress on the car. LOL.
[Re: Norm]
#1474222
08/03/13 06:50 PM
08/03/13 06:50 PM
Posts: 1,513 AZ
Mike P
AZ
A 1967 Chrysler 300 that was about to be crushed donated the seats and buddy seat. The passenger reclines and the drivers is power (4 way). The car was a 4 door so the stop brackets had to be removed to allow them to fold forward but that was minor. As far as the under the dash units I usually pick them up whenever I find them in decent shape. At most the motors sometimes need to be lubed and switches cleaned. Brackets are usually pretty simple to fabricate. The rest of the parts I source locally; the compressor, a receiver dryer and usually a new universal condenser. After I have the components installed I buy the required fittings and hose and custom fit them then have the local Car Quest or NAPA crimp them. When I clean them up I normally paint the case interior body color and that’s about it. The one in the Plymouth is a really nice MARK IV unit from the early 60’s with a nice chromed metal faceplate and vents. I did a build thread on another site you might be interested in (it only runs about 5 pages the other pages are on other projects I was doing). As it’s most current post first you need to start on the bottom on page 16 and read it from bottom to top to somewhere on page 12. This should bring up page 16. http://www.hotrodders.com/forum/journal....=5&reverse=
