Re: does buildsheet show if a 22" rad car gets a shroud
[Re: scatcity]
#1474010
07/26/13 07:03 AM
07/26/13 07:03 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
440's Would be a 26" Rad Yoke out of the gate..22" Rad was N/A on a 440 in '70.
Not true, at least on a B-body. My '70 GTX is 440 auto with no a/c has the 22" rad opening. Came with the original 22" radiator and shroud.
With a/c is another story as well as the HD cooling package or some 4 speed or rear gear packages.
http://www.rosevillemoparts.com/reference_radiatorguide.php
[Re: gdonovan]
#1474011
07/26/13 07:58 AM
07/26/13 07:58 AM
Posts: 705 Morningside, Long Island
scatcity
You're deviating from the OP's specific question. We're NOT talking about B bodies, this is an E body question.
[Re: scatcity]
#1474012
07/26/13 08:06 AM
07/26/13 08:06 AM
gdonovan
Oakdale CT
If you looked at the link I provided it clearly states B/E use the same 22" radiator with 440 and automatic.
[Re: scatcity]
#1474014
07/26/13 08:17 AM
07/26/13 08:17 AM
gdonovan
Oakdale CT
70 E Body 22" Rad yoke: 2998957 383 CI 2BBL, 2998960 383 CI 4BBL. Auto trans. Those were the only two 22" rads available FOR AN E BODY with a BB engine and A/T.
http://www.dodgecharger.com/forum/index.php?topic=87954.0
There is ample evidence that 22" inch radiators were in 440 e-bodies, don't get cranky at me for pointing it out.
[Re: gdonovan]
#1474015
07/26/13 08:17 AM
07/26/13 08:17 AM
scatcity
For the 2nd time, he's NOT asking about B Bodies, why are you being so adamant about dragging B Bodies into this question ?
Tony, what engine are you asking about ?
And sure, I could be wrong, wouldn't be the first time.
Not cranky either.
[Re: scatcity]
#1474016
07/26/13 08:24 AM
07/26/13 08:24 AM
gdonovan
Oakdale CT
For the second time you are not listening.
B and E bodies came with 22" radiators with 440 automatic, you made the blanket statement they DO NOT which isn't true. I was just pointing out this was incorrect and pointed out that e-bodies used the same part number radiator as a b-body.
Did you even look at the links I provided?
[Re: scatcity]
#1474019
07/26/13 09:06 AM
07/26/13 09:06 AM
gdonovan
Oakdale CT
So what depicted getting a shroud then ? 6BBL and Shaker w/ 440 w/ A/T ?
I would go out on a limb and *theorize* that if a car had a 440 with a 22" radiator that it came with a shroud to maximize the cooling with the smaller radiator.
Tossing a shroud on had to be cheaper than a 26" rad, I know "back in the day" my 22" radiator was marginal with the miles that were on it.
A Chrysler engineer I'm friends with stated that a radiator loses something like 50% of its ability to shed heat in the first 4-5 years.
P.S. My GTX had the same fixed fan as the 440+6 car shown above, what a noisemaker that was.
[Re: scatcity]
#1474020
07/26/13 10:22 AM
07/26/13 10:22 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
...So what depicted getting a shroud then ? 6BBL and Shaker w/ 440 w/ A/T ?
FWIW, here is cooling system page from the 1970 service manual. It shows when shrouds were used. However it also shows only 26" rads with 440 engines as Scatcity said. As already said here, you never know with Ma Mopar.
[Re: moparfan53]
#1474022
07/26/13 11:03 AM
07/26/13 11:03 AM
Posts: 1,010 Alberta, Canada
krisiesmopes
Alberta, Canada
^ but to go opposite to that, the parts manual says:
RADIATOR CORE FAN SHROUD B/J W/383, 440 Eng. W/22" Core W/O A/Cond. 2998328 (same as B body).
It also lists radiator:
B,J,R,W 70 440 22" No Air conditioning stamped 2998960 part # 2998957
Also the same as above for 383, but as well for 383 lists the same PART #, with 2998954 as a stamping # and 2998957 as a stamping # with A/C)...
So, my guess is that as a possibility, they ran out of some rads on the line. Shift supervisor ok'd a replacement, and those were used. It was noted, and made it into the final version of the parts book.
Now logic to me says, if you have a 440 in an E body, a shroud is a must...so I would think the ones that got the small rad, got a shroud (2998328).
I think on the BS if it listed a 22" (would that be 60?) you would get a shroud, or maybe if it was an export (Canada) car it could be X55? (radiator air shield 70-71)
