"Special Handling Car" ?? #14734
03/09/05 05:15 PM
03/09/05 05:15 PM
Anonymous OP
Anonymous OP
I've got a 1970 Challenger that is not a RT and the build sheet says "special handling car" typed on the lower part of the form. It also says "Chall Carry" written in red grease pencil. Anyone see this before and can tell us what this means?
Re: "Special Handling Car" ?? #14735
03/09/05 05:18 PM
03/09/05 05:18 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
That question was on here a couple weeks ago. Someone said it was for special handling of the assembling of the car. Like a ceo wanted it or factory type head honcho, or a fleet vehical. It doesn't mean the car has a special suspension. More like 'shipping and handling' type handling.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: "Special Handling Car" ?? [Re: amxautox] #14736
03/09/05 05:22 PM
03/09/05 05:22 PM
Anonymous OP
Anonymous OP
Well thay majkes sense since the car is loaded to the max and it also says "Carry" all over the build sheet. I wonder who the exec was?
Re: "Special Handling Car" ?? [Re: amxautox] #14737
03/09/05 05:23 PM
03/09/05 05:23 PM
P.E.I. eastern Canada
N
newportrider Offline
N
Would that be" make sure all the nuts and bolts are tight" kind of option.LOL
Larry
Re: "Special Handling Car" ?? [Re: newportrider] #14738
03/09/05 05:30 PM
03/09/05 05:30 PM
amxautox Offline
amxautox  Offline
THAT could be a good idea too.
Tom
author unknown
Re: "Special Handling Car" ?? #14739
03/09/05 06:16 PM
03/09/05 06:16 PM
MoreParts Offline
MoreParts  Offline
It should probably have a fender tag to with just "Special Handling Car" on there as well. I pulled a few of those tags from the junk yard that were on wrecked ex-police vehicles.
Re: "Special Handling Car" ?? [Re: MoreParts] #14740
03/09/05 07:17 PM
03/09/05 07:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Anything that wasn't NORMAL in the options groups was a special handling car. That covered color combos that were not considered normal or a slanty B body car with an 8 3/4 or buckets in a wagon etc.
Re: "Special Handling Car" ?? [Re: MoreParts] #14741
03/09/05 07:24 PM
03/09/05 07:24 PM
Anonymous OP
Anonymous OP
Fender tags are MIA. It sure would be cool to know the specific odity that made this car a "special handling car"!
Re: "Special Handling Car" ?? #14742
03/09/05 07:55 PM
03/09/05 07:55 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Does the inner fender have tag screw holes for more than one fender tag ??
Re: "Special Handling Car" ?? [Re: stateline] #14743
03/09/05 08:33 PM
03/09/05 08:33 PM
Anonymous OP
Anonymous OP
It's hard to say because it has A/C hoses and Cruise control mounting holes and a White tag with green letters telling about the smog stuff all mounted in the same small area.
Re: "Special Handling Car" ?? #14744
03/09/05 10:43 PM
03/09/05 10:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Does the Vehicle Order Number begin with a letter? Maybe a "Q"? Also, what are the Y codes?
Barry
Re: "Special Handling Car" ?? #14745
03/09/05 10:44 PM
03/09/05 10:44 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
On the build sheet ...What does the order/sequence number start with? Is the car a 71?
Re: "Special Handling Car" ?? [Re: Alaskan_TA] #14746
03/09/05 10:47 PM
03/09/05 10:47 PM
JRepucci Offline
JRepucci  Offline
Barry , I have a question for you.... my sequence/order number starts with an R.... do you know what that means?
Re: "Special Handling Car" ?? [Re: Alaskan_TA] #14747
03/09/05 10:48 PM
03/09/05 10:48 PM
Anonymous OP
Anonymous OP
Barry
The build sheet is a little mouse bitten so it is hard to read in places. The Vehicle order number begins with "C07". What are "Y" codes??
Re: "Special Handling Car" ?? #14748
03/09/05 10:53 PM
03/09/05 10:53 PM
JRepucci Offline
JRepucci  Offline
top right ...sales codes Y05,Y39,Y14...etc.
C...Canadian? on the order number....is it a 70'
Re: "Special Handling Car" ?? [Re: JRepucci] #14749
03/09/05 11:07 PM
03/09/05 11:07 PM
Anonymous OP
Anonymous OP
That part of the build sheet is missing.
Re: "Special Handling Car" ?? [Re: JRepucci] #14750
03/10/05 01:50 AM
03/10/05 01:50 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
"R" VON prefixs are normally Y22 or Y28 cars. Do you have the Y codes for it? Is it a '71 model?
Barry
Re: "Special Handling Car" ?? [Re: Alaskan_TA] #14751
03/10/05 01:55 AM
03/10/05 01:55 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The date is right ahead of the VON (technically the date is part of the VON) so depending on where the C07 is on the sheet it may be the SPD?
C07 = December 7, 1969 for a 1970 model car.
Are the last six digits of the VIN in the 212xxx range?
(edit - typo, meant 212xxx not 202xxx)
Barry
Re: "Special Handling Car" ?? [Re: Alaskan_TA] #14752
03/10/05 02:14 AM
03/10/05 02:14 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
I doubt a standard VON would be on the BS, more likely a 00-09 or Alpha VON is more likely.
Amazing how an unchallenged lie can become the absolute truth.
Re: "Special Handling Car" ?? [Re: beepbeep] #14753
03/10/05 02:35 AM
03/10/05 02:35 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hey beepbeep,
Just curious, I know you look at this stuff.
Have you seen any 1970 Hamtramck VONs in the 000xxx to 09xxxx range with any Y codes other than Y05, Y14 or Y16 or combinations of the three yet? I have 611 VONs on file in that range for 1970 Hamtramck cars so far, but they are all either Y05, or Y05 with Y14, or Y05 with Y16, or Y05 with both Y14 & Y16. Have you seen anything different yet?
Again, just curious.
T/Ake care,
Barry
PS - If anyone knows what a "W" VON prefix means, please let me know? I have a 1970 Valiant from Hamtramck and a 1970 Challenger from LA on file with "W" VON prefixs, but I have no clue what it may mean.
