Re: distributor wire
[Re: rowin4]
#1473675
07/24/13 11:17 PM
07/24/13 11:17 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
It should be consistent and soft, like the others(hopefully). Ohm it and make sure it ohms as the others do. Ignition wires can go bad from the outside in, or inside out. If it is crunchy on the inside, the spark was jumping a gap, and burning everything from the inside out.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1473676
07/24/13 11:37 PM
07/24/13 11:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Should have made myself more clear on which wire. It's the small wire, maybe 18 gage wire, the one coming out from inside the distributor to the coil.
[Re: rowin4]
#1473679
07/24/13 11:56 PM
07/24/13 11:56 PM
Posts: 75,134 A Banana Republic near you.
JohnRR
It on a older GM like 1963 single point distributor. Resister wire? Will have to look that up.
Yes resistor wire , they used that instead of a ballast resistor.
Easy way to tell , put an ohm meter on it .
