Best Spark Plugs for My Application
#1473662
07/24/13 10:53 PM
07/24/13 10:53 PM
Posts: 10,948 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
What spark plugs should I put in my 440 street car? It's 9.5 to 1, .040 over, Comp Cams XE274 cam, cast pistons, LY rods, RPM intake, Holley 750 vacuum secondaries, TTI 1/78 headers, 2.5" exhaust, H pipe, turbo mufflers to the rear bumper, 3.91 gears.
I know these are pretty basic questions. I haven't run a performance V8 in decades...
I’m listening.
Re: Best Spark Plugs for My Application
[Re: topside]
#1473664
07/24/13 11:13 PM
07/24/13 11:13 PM
Big Bad Bee
Spokane Valley, WA
Closed chamber. 2.14/1.81 Harland Sharpe Roller Rockers, ball/cup push rods. MP electronic ignition conversion kit.
I’m listening.
[Re: Big Bad Bee]
#1473669
07/25/13 11:37 AM
07/25/13 11:37 AM
BradH
Closed chamber factory iron heads or aluminum ? Ron
Factory Iron with a pretty aggressive port and polish.
Accel 137 and Autolite 75 worked well for me w/ similar compression and iron heads.
Higher compression (or poor quality pump fuel) could require going a bit colder, which would be Accel 134 and Autolite 73.
I did NOT have good results w/ the latest Champion equivalents and suggest you pass on those particular plugs.
