What Gasket Sealer #1473542
07/24/13 10:46 PM
07/24/13 10:46 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I'm getting ready to button up my 440. What do you sealer use on the oil pan, water pump housing, water pump, valley pan, intake, oil pump, fuel pump, water neck seals? are there any you don't use a gasket on? I will be using a Milodon windage tray and have two gaskets.
Thanks,
Lindy
I’m listening.
Re: What Gasket Sealer [Re: Big Bad Bee] #1473543
07/24/13 10:58 PM
07/24/13 10:58 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
water pump housing,
water pump,
valley pan,
intake,
Oil pump,
fuel pump,
Water neck seals?
NONE ON THE ABOVE
to hold gaskets in place I use a dot of 3M weather stripping yellow adhesive"GORILLA SNOT" I call it.
Silicon on the corners of valley pan cover and if needed to seal valley cover to heads
home of the
Sox and Martin Hemi Duster
Re: What Gasket Sealer [Re: HEMIFRED] #1473544
07/24/13 11:17 PM
07/24/13 11:17 PM
Spokane Valley, WA
Spokane Valley, WA
Thanks, Fred. The thought of not having to use goo on that pretty new block makes me smile. I don't have any of that snot you speak of but I've got some clear 3M seam sealer that's pretty sticky.
And a follow up question. For ease of installation, which items including accessories and mini starter do you put on before you drop the engine and trans and which do you put on after? How do I set up the headers so that when I drop the engine they are already in place to bolt in without killing my beautiful aprons and them getting in the way?
I’m listening.
Re: What Gasket Sealer [Re: Big Bad Bee] #1473545
07/24/13 11:28 PM
07/24/13 11:28 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
definatly put the starter on AND the wires.make sure you check your routing.youll save yorself a huge headache.
Re: What Gasket Sealer [Re: Big Bad Bee] #1473546
07/24/13 11:32 PM
07/24/13 11:32 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
noithing is better than installing a Hemi from ther bottom . remove K member then mount evrything on the K member. easiest header install ever. not even a scratch on them. riase car lower onto K member
home of the
Re: What Gasket Sealer [Re: HEMIFRED] #1473547
07/24/13 11:41 PM
07/24/13 11:41 PM
Spokane Valley, WA
Spokane Valley, WA
I've seen a couple of posts where guys did it in assembly line fashion. Looks great and I have room but I have my front end completely assembled, bumpers on, etc. I don't know if it would be worth undoing all that.
I’m listening.
Re: What Gasket Sealer [Re: Big Bad Bee] #1473548
07/24/13 11:49 PM
07/24/13 11:49 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Gaskets are made to seal. I dont know why everyone thinks you need to use sealer on a gasket, which purpose in the first place is to seal the component! Using a Hi Tack product is fine, if you need to hold something in place, lets say for future removal etc.
Let the gaskets do their job, as a gasket. Small and minor imperfections can use a tiny dab of sealer, but I hardly use any sealers on any engine I build. The gaskets are there for a reason. If they leak, then the surfaces are warped, not cleaned,pitted, offset and so forth.
Blue, black, grey and red silicone in your oil pan is never a good thing.
Buy good gaskets, dont over torque them, make sure surfaces are clean, and all is well...
RIP Monte Smith
Re: What Gasket Sealer [Re: Big Bad Bee] #1473549
07/25/13 01:28 AM
07/25/13 01:28 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Gasgacinch...I use it to hold the gaskets in place during assembly.
Re: What Gasket Sealer [Re: loaderpro] #1473550
07/25/13 01:35 AM
07/25/13 01:35 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Hi-Tack
Re: What Gasket Sealer [Re: MrFoFody] #1473551
07/25/13 02:08 AM
07/25/13 02:08 AM
Spokane Valley, WA
Spokane Valley, WA
awesome!
I’m listening.
Re: What Gasket Sealer [Re: Big Bad Bee] #1473552
07/25/13 04:37 AM
07/25/13 04:37 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Perm a tex aviation gasket maker, lightly brushed on any gasket will seal like a champ.
Re: What Gasket Sealer [Re: CompWedgeEngines] #1473553
07/25/13 10:57 AM
07/25/13 10:57 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Use MoPar RTV black in the corners of the valley pan, and the gorilla snot is available at every parts store if you need to hold a gasket in place for assembly (you can just use a small dab of RTV as well). If I don't have the MoPar stuff the Permatex RTV black works okay.
Don't use the RTV red or blue, they're for Chevrolet and Ford engines, respectively. MoPars get black.
Re: What Gasket Sealer [Re: bonefish] #1473554
07/25/13 11:08 AM
07/25/13 11:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Im with Fred.I do use Permatex brown on some water pump gaskets though.Mainly where they bolt to an aluminum cover like a SB.They usually have some pitting and it might prevent a leak.Rocky
Chrysler Firepower
Re: What Gasket Sealer [Re: loaderpro] #1473555
07/25/13 02:04 PM
07/25/13 02:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
I also use it to seal the cork gaskets up on all sides Follow the instructions, Gasket Cinch is way easier to clean up after removing the parts from the motor than the 3M "Gorilla Snot" is
Re: What Gasket Sealer [Re: Big Bad Bee] #1473556
07/25/13 05:21 PM
07/25/13 05:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Using quality gaskets is the key.Cheap gaskets will need sealants.
Superformance gaskets are excellent.
Nautilus Racing-
Re: What Gasket Sealer [Re: Chris2581] #1473557
07/25/13 09:57 PM
07/25/13 09:57 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
MY FAVORITE
■Remain a liquid when exposed to air, but cure when confined between mating flanges
How Loctite® Anaerobic Adhesives Work
Anaerobic adhesives remain liquid until isolated from oxygen in the presence of metal ions. Though anaerobic applications differ widely, in most cases the adhesive provides high shear strength and temperature resistance. Anaerobic adhesives fixture in minutes at room temperature and fully cure within 24 hours. Full cure of anaerobics may be achieved more rapidly using short-term exposure to heat (e.g. 30 minutes at 120°C).
home of the
