Re: temp wire bulkhead location
[Re: Clanton]
#1473466
07/25/13 01:20 PM
07/25/13 01:20 PM
Posts: 508 Cincinnati, Ohio
superbeedave
Cincinnati, Ohio
I only have diagrams for a 69 Superbee but it may be the same. It shows that the violet wire goes into "R" at bulkhead which looks like middle far right bottom below "J" which is where the 10R wire from starter relay goes thru with a fusible link. I hope this helps ya!
