Pull the connector(s) off of the door electrical terminals & jump fire directly from the battery positive post to them & see if they operate correctly. this'll tell you if the issue is in/at the doors or a voltage drop to them. Not sure how the reg issue is connected/affecting the door operation since when the reg goes out (open) the system voltage will start to go down but not enough to affect the doors immediately which is what I'm hearing is happening. I'd continue to check each connection on those 2 circuits & regs blow from either a bad one (which doesn't sound like the case here with repeated reg replacements) or too much current flowing in the field circuit over time (occaisional dead short or brush grounding or internal alt field fault). EDIT make sure the door have good continuity to ground also when checking them (jumper wire or ohmmeter)
