Steering Shaft Install Question #1472949
07/23/13 10:17 PM
07/23/13 10:17 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I'm have been following the FSM to disassemble, restore and reassemble my 1970 A body column shift steering column. All has gone well so far but I'm having some trouble getting the shaft pulled up through the upper bearing. The FSM mentions a specific tool for this purpose. I know not to hammer the shaft up into the bearing. Any pointer would be appreciated/
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Steering Shaft Install Question [Re: FJR doc] #1472950
07/26/13 03:02 PM
07/26/13 03:02 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i used a piece of pipe from a harley handlebar and the st,shaft nut to pull it through.
Re: Steering Shaft Install Question [Re: cuda-sweden] #1472951
07/26/13 03:43 PM
07/26/13 03:43 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Finally got the shaft installed and the column completed. I had an epiphany yesterday and realized that I installed the column lock wheel the wrong way. DUH!
Kevin
