Re: Guys build me a 572ci street/ strip motor
[Re: griff70440]
#1472858
07/24/13 12:38 PM
07/24/13 12:38 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
How much power are you wanting to make? Or how fast do you want to go? Weight of the car?
[Re: griff70440]
#1472864
07/24/13 09:13 PM
07/24/13 09:13 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Thanks for the replies.
The car should weigh 2800-2900lbs.I would like to make over 800hp and still be able to drive 5 miles into town. Is it possible?
Think Drag Week...many cars with those power levels are racking up some highway miles. With today's technology, 800-900 very streetable HP is cake...even N/A with no power adders.
[Re: griff70440]
#1472865
07/24/13 09:15 PM
07/24/13 09:15 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Without batting an eye.
I drove around with 800+hp N/A 499ci 20 year ago and currently drive around with a 900hp N/A 417ci smallblock.
Ive put over 30 miles on each one in a single night without issue.
There are so many ways to build an 800hp 572 that's driveable it isn't funny.
[Re: jim sciortino]
#1472866
07/24/13 10:57 PM
07/24/13 10:57 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Bore 4.6 Stroke 4.3 B1 Heads 11:1 compression pistons, long rods. 1.7 rockers, cam 275@.050 .750 lift, 106 LCA Single plane intake with 1200cfm carb 2.125" headers This should make around 850ftlb of torque at 4700rpm and 860hp at 6000rpm. It should make 550ftlb of torque at 2500rpm, excellent street manners and a good low rpm engine that should last for years.
[Re: griff70440]
#1472867
07/25/13 09:35 AM
07/25/13 09:35 AM
an8sec70cuda
Like everyone else said, that's easily done. If all you want to do is make 800 hp, then you can just use the Indy -1 heads...cheaper than the B1 stuff. Although you'd have more room to grow in the future w/ B1 heads. The -1 Indys are pretty much maxed out at the 800-850 hp level I believe. The new World blocks are good stuff, just heavy. I'm building another big hemi w/ a World iron block now.
[Re: an8sec70cuda]
#1472868
07/25/13 09:45 AM
07/25/13 09:45 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A Indy Maxx aluminum block would be your very best choice for a block.It over a 100 lbs lighter than the other blocks and just as strong if not stronger and can be repaired!Being you don't already have heads go with the 572-13 heads.Complete as per Indy these type engines weigh less than 500 lbs.I have also noticed an all aluminum engine runs a lots cooler.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1472869
07/25/13 11:32 AM
07/25/13 11:32 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If I were to detune my 528, it would be around 800 hp, minimum with proper compression and a bit more moderate cam. Torque would be at least as good as B1 heads from 5000 rpm down, but would probably not be a good above that. In your case, it all depends on your plans for track use, as the car won't have sufficent traction to use even 750 hp on the street. That, and total cost. Don't rule out a set of SR heads ported to max wedge size. They should make 750 hp, be very responsive, and make that power well below the B1s and the most likely the 440-1 heads as well. They will also be a LOT cheaper to put together.
[Re: MRMOPAR622]
#1472872
07/25/13 03:33 PM
07/25/13 03:33 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
... Indy block
[Re: Whompin_Wedge]
#1472874
07/25/13 03:59 PM
07/25/13 03:59 PM
Defbob
Norwich CT USA
Indy block is a good bang for the buck, I would definately go aluminum block and b1's!
Casey
I recommend a higher quality block.
