Re: CSR Sheild with a JW Bell?
[Re: Dragula]
#1472842
07/23/13 07:34 PM
07/23/13 07:34 PM
Triple Threat
Renton Washington
I think in another thread you said you were trying to get the car legal for 9's. If that is the case, the blanket isn't legal.
Stock bell with the CSR would be the easiest solution.
[Re: Triple Threat]
#1472843
07/23/13 08:32 PM
07/23/13 08:32 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Why isn't a blanket legal? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Triple Threat]
#1472844
07/23/13 08:39 PM
07/23/13 08:39 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
I switch between the Hemi and the W2 motor. Trans bell is long gone on all my tranmissions. I just keep different bells...
[Re: Dragula]
#1472846
07/23/13 09:45 PM
07/23/13 09:45 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Jw bell and a blanket. If you cut the front mounting off the csr you would only have a single strap holding it on. Don't think that would work real well. I have a jw bell and stroud blanket and they work great together, took car on a 72 mile cruise the other weekend and trans never got over 175 degrees. That's with a 8 in 4400 conv.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Dragula]
#1472850
07/26/13 12:16 AM
07/26/13 12:16 AM
1967dartgt
Hilltown Pa
A blanket is legal. No shortie csr. They do make alum shields but you need a big tunnel to clear.
[Re: 1967dartgt]
#1472851
07/26/13 06:47 AM
07/26/13 06:47 AM
Dragula
Yeah I already figured out the alum one isn't even come close to fitting...Must be for a truck...
![](/ubbthreads/images/graemlins/violin.gif)
