not sure about cam specs lingo but should'nt it read as...
110* lobe seperation angle with a 106* intake center line for a 4* advance?
this is what a hughes whiplash cam is for, low comp stock engines.
early intake close to build cyl pressure and not bleed off lowend torque.
I have 2 SB whiplash roller cams in stock 318s and 1 BB whiplash cam going in my 77 lopo 440 engine.
that summit cam listed said with a "with sacrifice of some low end for a gain in the mid to upper rpm."
not with a low comp engine. that makes a dog under 3000 rpm.
IIRC, is comp cams the one with the most lobe failures at break in in the last few yrs?
