Crossmember spacers on Ramchargers???
#1472394
07/23/13 01:02 AM
07/23/13 01:02 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Hey guys, I need some help and maybe even a few pictures.
Im having a 518 installed in my 93 Canyon Sport with a 440 conversion.
When the original 440/727 swap was made the tranfer case/transmission crossmember was installed directly to the frame. IIRC all the RC's had a 3/4" or so spacer on this crossmember to drop it down a tad.
Does anyone have any pictures they could post, and maybe a measurement on the spacers used?
One issue I have had is that the PCV valve on the drivers side valve cover has no clearance with the correct small diameter brake booster. I have had several 440 powered trucks, and this has never been an issue before.
My thinking is that those spacers will tilt the engine down just enough to gain the needed space for the PCV valve to fit. As is I would have to pull the booster to change valve cover gaskets, and I know that this can normally be done without having to do that. Ive done it many times.
I am using stock valve covers, fit fine in the previous truck. Also I wonder if the spacers were to help with driveshaft angle since its so short.
I want to make sure this is buttoned up correctly and hopefully for the last time.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Crossmember spacers on Ramchargers???
[Re: 340SHORTY]
#1472402
07/23/13 05:17 PM
07/23/13 05:17 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Are you guys useing the 4x4 engine brackets or the 2x4 version??
It has the correct 4wd engine brackets.
Scratch none of the ones I've seen had a skid plate. I can't recall if the 2wd ones I've had or worked on had them bit the 4wds did
[Re: 76dodgeboy]
#1472403
07/23/13 06:03 PM
07/23/13 06:03 PM
hp383
State of Confusion
Cutting my own may be possible. But ideally I would like to know the correct length.
I was hoping someone with a ramcharger might be able to take a look under theirs.
[Re: hp383]
#1472404
07/23/13 06:31 PM
07/23/13 06:31 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I would tend to believe the 4X RCs amd W series trucks would have the same mounting system..
I am truckless..
[Re: 76dodgeboy]
#1472413
07/24/13 04:46 PM
07/24/13 04:46 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I used them on my 446/2 wire 518 2wd 86 RC. They were the original ones it had and I went ahead and reused them for the conversion.
Moparlee
[Re: 76dodgeboy]
#1472414
07/25/13 12:13 AM
07/25/13 12:13 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
Im starting to think it was 2wd only. Haven't seen any 4was with them yet when searching pics.
That explains the reason why they're not in the can of bolts for the last 4wd RC that I parted out
[Re: hp383]
#1472418
07/25/13 03:42 AM
07/25/13 03:42 AM
hp383
State of Confusion
And the spacers may indeed be a good plan. I did have the taller diesel style blocks installed in the rear, so the spacers would help correct the driveshaft angle.
I know the diesel truck crosmembers had a special spacer attached to the t-case mounting surface that is about an inch to help with driveline alignment.
So if I could find an inside diameter, and length. I can either buy some, or find some.
I have 1"OD and 0.50"ID aluminum readily available.
[Re: 76dodgeboy]
#1472419
07/25/13 08:20 PM
07/25/13 08:20 PM
BulletBob
Back home in PA
Must be a 2wd only than. Hey Bob can you check your 2wd and measure them if it has them? I think we should still is them for clearance even if its under an inch Mr Johnson.
I sure can ! I'll be home in 30 mins or so
