P/N HELP ON CRANKSHAFT 2658 885 #147113
11/07/08 11:18 PM
11/07/08 11:18 PM
Gateway to the West.
hemi_harvester Offline OP
HAVE A CRANK W/ PART # 2658885 TRYING TO SEE IF ITS SPECIAL.. ANY HELP..
THANKS
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: hemi_harvester] #147114
11/09/08 11:35 AM
11/09/08 11:35 AM
dogdays Offline
dogdays  Offline
First of all the forging number or casting number on a crank isn't the part number.
Second if it doesn't have an 8-bolt crank flange it isn't a Hemi crank.
Third, in reality most Mopar cranks are the same across the board.
Fourth, do an on-line search for Mopar crankshaft forging numbers and you'll find it.
R.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: dogdays] #147115
11/09/08 02:45 PM
11/09/08 02:45 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I thought there were some 8 bolt flange BB crankshafts for industrial or truck applications.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: Snoopy] #147116
11/09/08 03:02 PM
11/09/08 03:02 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Some of the early big block cranks where 8 bolt and where longer, 440 source has great info on cranks, also mopar did offer a small block 8 bolt crank back in the 70's.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: dogdays] #147117
11/10/08 12:57 AM
11/10/08 12:57 AM
R.
1.What ever you want to call the # its not to be found
2. it does have a 8 bolt flange
3. Mopar made several de-stroked hemi cranks for various reasons
4. Myself and several other have looked numorius places with no luck.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: hemi_harvester] #147118
11/10/08 01:51 PM
11/10/08 01:51 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
that crankshaft looks like it has stamped, not cast numbers??
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: 1965_PLYMOUTH] #147119
11/10/08 01:54 PM
11/10/08 01:54 PM
CENTRAL MINN
CENTRAL MINN
measure the crank main journals if you have a micrometer or dial caliper. does the crank have a longer shank coming out the back end. the 1961 and older engines had bolts with nuts holding the flywheel to the crank.
Re: P/N HELP ON CRANKSHAFT 2658 885 [Re: 1965_PLYMOUTH] #147120
11/16/08 12:00 PM
11/16/08 12:00 PM
dogdays Offline
dogdays  Offline
OKAY, I was going on the number being mid-60s. If it was an early 8-bolt crank it would have a number starting with a "1".
If it is indeed an early crank it will have 8 bolts with non-threaded holes and no pilot ring for a torqe converter nose.
I think it will have threaded holes and it is probably what was mentioned above. From the picture it certainly looks like a forged crank.
MOPAR was selling 8-bolt "Kellogg" Hemi cranks in the '70s for good prices, hopefully it's one of those because they were super cranks.
R.
