1973 Roadrunner inner fenders #1470871
07/20/13 07:09 AM
07/20/13 07:09 AM
PA
RoadRunner73 Offline OP
PA
I'm working on doing the engine swap on my 73 RR from small block to big block and I see that there are inner fenders listed for big blocks,what's the difference between what I have and the big block one? And can I use mine or do I have to track down a big block inner fender?
1973 Plymouth Road Runner
Re: 1973 Roadrunner inner fenders [Re: RoadRunner73] #1470872
07/20/13 07:15 AM
07/20/13 07:15 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I put a 440 in a 74 satellite a few years back, it was a little tight but it fit. the big block inner fenders have some extra material trimmed out near where the exhaust manifolds sit so there is extra clearance. I used headers in my build and didn't worry about the extra clearance I was able to get at everything and it all fit with no interference.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 1973 Roadrunner inner fenders [Re: Jerry] #1470873
07/20/13 07:26 AM
07/20/13 07:26 AM
PA
PA
That's awesome to hear, I was starting to sweat a little my bird is at the body shop getting ready to be painted! So the big block inner fenders are just cut out in a spot to make more clearance for the manifolds?
Thanks - Ben
Re: 1973 Roadrunner inner fenders [Re: RoadRunner73] #1470874
07/20/13 10:07 AM
07/20/13 10:07 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
You will definately appreciate that feature when you have to change the spark plugs! DAMHIK!
With the metal removed, Ma Mopar utilized a rubber mat secured by clips that could be removed for access to the manifold area. This greaty aids accessability.
I supposed you could probably get away with cutting the sheet metal out and making a lip and then drill some holes for the clips. (With the engine out of course) A template would surely aid here.
Common sense is a flower that does not grow in everybody's garden
Re: 1973 Roadrunner inner fenders [Re: Ron_M] #1470875
07/20/13 01:29 PM
07/20/13 01:29 PM
PA
PA
Anyone mind showing me a picture oh how it looks?
Re: 1973 Roadrunner inner fenders [Re: RoadRunner73] #1470876
07/20/13 05:28 PM
07/20/13 05:28 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Here is a shot of when I had my 1973 Charger engine compartment painted. I would think this would be the same for other B-bodies as well.
As mentioned before, there is a rubber mat that clips over the opening to seal it from the elements.
Re: 1973 Roadrunner inner fenders [Re: cjskotni] #1470877
07/20/13 08:36 PM
07/20/13 08:36 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a shot out of the car...Yes the big block will fit with the small block right fender but it's close and the paint usually fries near the manifold...
Re: 1973 Roadrunner inner fenders [Re: screamindriver] #1470878
07/25/13 01:54 AM
07/25/13 01:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A pic I took yesterday of a '74 400 Charger's inner fender & cover.
Re: 1973 Roadrunner inner fenders [Re: RoadRunner73] #1470879
07/25/13 11:23 AM
07/25/13 11:23 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
if you look closely, you can actually see some of the dimples stamped in the sheetmetal for where the clip holes are to be drilled. Looks like they all used the same stamping, then they just cut away the metal on the BB cars.....
Re: 1973 Roadrunner inner fenders [Re: RoadRunner73] #1470880
07/25/13 12:39 PM
07/25/13 12:39 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Not quite on the subject of the inner fenders but I believe the big blocks used a pan unique to the 73-74 B bodies.
Re: 1973 Roadrunner inner fenders [Re: dart4forte] #1470881
07/25/13 10:58 PM
07/25/13 10:58 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes, with the introduction of the isolated K frame came the "971" oil pan...The pan was actually used past the 74 model year into the cordoba,magnum, etc... line of vehicles... 971 pan link
Re: 1973 Roadrunner inner fenders [Re: James74] #1470882
07/26/13 02:27 PM
07/26/13 02:27 PM
PA
PA
Has anyone taken the chunk out of their small block inner fender and mimicked the big block... and not ruined their inner fender?
