Re: replacement cab.
[Re: scratchnfotraction]
#1470421
07/22/13 12:36 AM
07/22/13 12:36 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
first problem I see is the TBI throttle pedel/cable is different than the 85 truck.
not sure what the fix will be at this time. the 85 has a square hole in the firewall and the 91 has a round hole.
not sure what the end of the tbi cable looks like, it was cut and MIA
Hp383 went from Bone stock 93 Rc to a carbed 440. I know we had the pedal cut and welded at a local shop do to the pedal hang when we swapped it. I was hoping to go there today or tuesday but funds dont allow it. Maybe my next day off. I can get pics.
[Re: magnum440d100]
#1470423
07/22/13 11:19 AM
07/22/13 11:19 AM
Posts: 15,487 Florida
scratchnfotraction
Whatcha doin with the red carpet ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Looking great
tossing it out, it got wet with no doors the day i got it home. it was not in bad shape if you want it,just cover the ride. ![](/ubbthreads/images/graemlins/thumbs.gif)
plenty of sunshine so I can get it dry, maybe dry already.it is laying in the yard spred out.
how do you fix the square hole/round hole in the firewall for the cable?
yea pics would be great. ![](/ubbthreads/images/graemlins/scope.gif)
#1470424
07/22/13 04:40 PM
07/22/13 04:40 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
Looking great
Flat rate box ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Shipping to 92508. Wonder how much? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: magnum440d100]
#1470425
07/22/13 05:34 PM
07/22/13 05:34 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Flat rate ![](/ubbthreads/images/graemlins/laugh2.gif) . They don't have that big of flat rate.
[Re: 76dodgeboy]
#1470426
07/22/13 05:40 PM
07/22/13 05:40 PM
scratchnfotraction
parcel post is cheap. i let you know what i can find for it. I check on it tonight and flod it back up if it is dry. good thing you said something, it was going to the trash with some other stuff. if anyone needs anything off the cab speak up in a PM or something all free you cover the ride. ![](/ubbthreads/images/graemlins/thumbs.gif)
#1470427
07/22/13 06:13 PM
07/22/13 06:13 PM
magnum440d100
woodcrest, CA
Was the old cab a 4 speed hump? If so, and I'll make it worth your while. Had an offer from another member, but my email dumps emails every so often, and I can't find them.
Thanks mike ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: redraptor]
#1470431
07/23/13 09:32 PM
07/23/13 09:32 PM
scratchnfotraction
Yeah it's funny how some things are so similar but you can't really use anything but the seatbelts & dashpad out of that cab. What about the HVAC?
the control switch in dash is MIA, but the vac lines are in good shape, the heater/a/c was all working when parted out a couple days ago.
I will be removing the heater core box and all duct work.
I am going to strip it down and install everything from my 85 truck exept the heater core box.
I figure I can cut a patch piece with the square hole needed for the 85 throttle cable and weld it into the 91 cab while it is off, gonna take a couple days to patch the floor and driver rocker panel.
working on finding some patch panels, i rather weld in stock preformed pieces.
at this point the 1 hole is less than the 7 holes in the 85 so it might ride as is if it slows me down too much. ![](/ubbthreads/images/graemlins/laugh2.gif)
#1470433
07/28/13 09:18 PM
07/28/13 09:18 PM
scratchnfotraction
with all of the LE trim inside I think the water leak was unseen. it has had a new gasket/winshield replaced at one time. lots of screw holes for the headline foam padand trim pieces, told ACe i am not going for looks and I am not welding all those holes,allmetel is faster. ![](/ubbthreads/images/graemlins/laugh2.gif) guess i need to find 2 low back bucket seats and 2 drive side lower bases(no flip hinge) from a RC/TD not sure I am ready for race seats in the daily driver yet. ![](/ubbthreads/images/graemlins/shruggy.gif)
#1470434
07/28/13 10:08 PM
07/28/13 10:08 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
You can actually bolt the tilt bases solid. Pull the latch and hinge and bolt it to the floor. I did that on an old '86 I had.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
#1470437
07/29/13 07:45 PM
07/29/13 07:45 PM
Posts: 5,966 Greenville, PA
redraptor
Greenville, PA
Holy crap! Almost as bad as the raptor. Only thing left was the seatbelt anchor. Well it's still solid enough. Woulda liked a pic of the neighbors. ![](/ubbthreads/images/graemlins/scope.gif)
