Page 9 of 14 1 2 7 8 9 10 11 13 14
Re: replacement cab. [Re: old_goat] #1470560
10/20/13 06:18 PM
10/20/13 06:18 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
That canopy would look good on my Dually.. You can keep the boat, they cost money..
I am truckless..
Re: replacement cab. [Re: scratchnfotraction] #1470561
10/20/13 06:32 PM
10/20/13 06:32 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
Who the paints their driveshaft yellow......
Re: replacement cab. [Re: ChinooK440] #1470562
10/20/13 09:44 PM
10/20/13 09:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
3 guesses and the first 2 dont count....its easier to find when you drop it in those nasty mall parking lots...
I am truckless..
Re: replacement cab. [Re: 340SHORTY] #1470563
10/20/13 09:56 PM
10/20/13 09:56 PM
plymouth, NH
E
ejtmopar Offline
ejtmopar  Offline
E
plymouth, NH
I gotta say I admire your passion and follow through man! Keep up the good work!
Seems like a can never get a project done before a new one rolls in..
Re: replacement cab. [Re: ChinooK440] #1470564
10/21/13 11:07 AM
10/21/13 11:07 AM
scratchnfotraction Offline OP
I got that custom yellow shaft out of chicago for my yellow 440 truck.
some RV guy painted it up there.
so 3rd guess is no good either.
Re: replacement cab. [Re: scratchnfotraction] #1470565
10/21/13 07:43 PM
10/21/13 07:43 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
See what happens when you install a yellow shaft in a green truck !!! ... .... .... ...... .....don,t say i didnt warn ya... ............
Re: replacement cab. [Re: ChinooK440] #1470566
10/21/13 08:13 PM
10/21/13 08:13 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Poor greenie.
Re: replacement cab. [Re: ChinooK440] #1470567
10/21/13 09:44 PM
10/21/13 09:44 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
its a packers fan
Re: replacement cab. [Re: 72d100] #1470568
10/21/13 10:49 PM
10/21/13 10:49 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Are these cabs pretty much the same from '72-93?
I traded for a '92 D350 with a Cummins. I'd like to restore it..kinda
Yes, restore a '92
This is a cool thread. Did you just swap the dash for a different colored one?
I'm thinking about swapping mine out. Don't want it all cracked up.
Re: replacement cab. [Re: DusterKrazy] #1470569
10/22/13 01:52 AM
10/22/13 01:52 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The 2 differences Iv seen is the hole for the bulkhead connector and the steering colume saddle.. and the floor pan difference between the auto floor or the 4 speed/4X4 pan..
I am truckless..
Re: replacement cab. [Re: scratchnfotraction] #1470570
10/22/13 02:07 AM
10/22/13 02:07 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
bring your painter and that undercoating up for the turbocharged Shelby Dakota in my driveway.......
Re: replacement cab. [Re: ChinooK440] #1470571
10/22/13 10:42 AM
10/22/13 10:42 AM
Re: replacement cab. [Re: DusterKrazy] #1470572
10/22/13 10:53 AM
10/22/13 10:53 AM
Yes, restore a '92
sorta all the same,but lots of small changes over the yrs.I work with mid 80s trucks myself nowdays.
so 82-93 cabs. the 87-93 have the firewall hole for hydro clutch which is why I went with a 91 cab,and the auto floor pan has the changes made so it can run a manual trans with out being the large wide 4x4 trans tunnel. as far as I can tell that is...but I have a cut wheel and welder to make it so if not.
the steering colum mount has 4 predrilled holes for the hydro clutch MC mounting bracket that is need along with the large hole in firewall.
door striker post change in late 70s-early 80s, cab has a more ronded rear edge on the 70s cab, body lines changed in 82
the core supports change a couple times for headlight/grill changes also 82-85 86-89 90-93 IIRC
so there are some difference when mixing the parts, you just need to pick the right parts..
I used the 85 dash that was a tan color,I scuffed it, then spray primer,then a base coat with a clear coat of crysler champage.
Re: replacement cab. [Re: scratchnfotraction] #1470573
10/27/13 09:39 PM
10/27/13 09:39 PM
more progress...got the auto trans/linkage removed,then got the 5 speed bolted up to the engine. xmember bolted in stock location with a little cutting and grinding.
turned the trans mount around and trimed the edge of the xmember,then a little triming on the trans mount itself.
this allowed me to keep the stock saddle tank and my duel pipes..
the van motor mount had the engine pushed over making the header hit the frame, so i got the truck mounts swaped in with a new set of rubber biscuts.
this raised the engine back up and level sitting in the chassis, pulled the trans forward just a tad to make just enuff clearance at the back of the 5 speed.
in the pic you can see the dent in the header and how hight the correct truck mounts lift the engine back up level. it was tilted a lot to make the pipe rub the frame edge.
this also let me get the exhaust pipes bolted back up to headers with less hassles. i found those 3 lifter/rocker arm taping sounds I had in the cab with rusted floors...muff shop miss 3 good spots on the top of pipes when welding them up.. i bet the goob did that on purpose...i saw him check it with a mirror.. but never double checked his work myself.
look for the black soot blowing out the welds on the pipes in the pics. I will get those welded up before cab goes back on for sure..cant stand exhaust leaks.
got the poly cab bushing ready to go, orderd them for the 85 truck,as they dont seem to list a set for a 91 cab..it is the same bushing set. the differance is the bolts and how the bushing washer stack up.
85 has a shoulder bolt with a nut/washers and goes in from the top with nut on bottom.
91 uses a bolt with metel sleeves and a couple washer with a big ID hole and a couple more with a smaller ID hole to sit on the sleeves...sort like a shoulder bolt would. and bolts go in from bottom into captured/adjustable speed nuts in cab floor.
just have to use washer supply and maybe a few of the washers from the stock cab bushing.. i used a couple of my old ones to get washers where the needed to be and take up enuff of the bolt so it is not to long.
drive shaft did not work out, so I will chop down a long one to fit.comes up just a little short.
next up is cutting the hole in cab floor and mounting the cab to frame.
the under hood wiring goes in place.
Re: replacement cab. [Re: scratchnfotraction] #1470574
10/27/13 09:40 PM
10/27/13 09:40 PM
pics
Re: replacement cab. [Re: scratchnfotraction] #1470575
10/27/13 09:41 PM
10/27/13 09:41 PM
another pic
Re: replacement cab. [Re: scratchnfotraction] #1470576
10/27/13 09:42 PM
10/27/13 09:42 PM
looky see
Re: replacement cab. [Re: scratchnfotraction] #1470577
10/27/13 09:42 PM
10/27/13 09:42 PM
slow going,but going.
Re: replacement cab. [Re: scratchnfotraction] #1470578
10/27/13 09:43 PM
10/27/13 09:43 PM
another pic
Re: replacement cab. [Re: scratchnfotraction] #1470579
10/27/13 09:44 PM
10/27/13 09:44 PM
more work
