Page 8 of 14 1 2 6 7 8 9 10 13 14
Re: replacement cab. [Re: scratchnfotraction] #1470540
10/01/13 09:54 AM
10/01/13 09:54 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I sent you a message on REC and here I believe. Local guy parting an RC chassis and I have some front springs. You can have springs just pay for the ride. He said make offer on hangers and shackles
Re: replacement cab. [Re: 76dodgeboy] #1470541
10/01/13 06:53 PM
10/01/13 06:53 PM
Lehigh Acres, Florida
rickstershemi Offline
The New Bedliner Poster Child......can't wait to see.....I Like Different....
Rickster
Re: replacement cab. [Re: rickstershemi] #1470542
10/01/13 07:12 PM
10/01/13 07:12 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
There's a 94-01 Body style around the area that's line x'd. He had it forsale awhile back and was dam proud of it. Very small group to sell to when its All lined.
Re: replacement cab. [Re: 76dodgeboy] #1470543
10/01/13 07:14 PM
10/01/13 07:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Im going to have to go back and read through. Haven't followed the whole time. Wanna know what liner and gun used. Would be Sick on a trail rig
Re: replacement cab. [Re: rickstershemi] #1470544
10/06/13 11:23 PM
10/06/13 11:23 PM
scratchnfotraction Offline OP
Rickster
Hi Rickster...yea, I guess I am kinda different when it comes to being me.
i got the dash painted and cleared, door panels painted/cleared, installed dash in the cab and started wireing it up. got the new gauge cluster with the white face gauges (thanks TOOMANY62s)
the chrysler champage color is nice looking in the all black cab shell and with the door panels to match is gonna make it even better.
and for now a woodgrain a/c bezel...i will find a black non a/c somewere down the line..
I thought the 85 harness bulkhead plug was going to be bigger than the hole in the 91 cab... but the 91 cab holes is correct size...it just looks smaller because of the plug on the harness I guess. but no cutting so all is good.
got 2nd coat of liner on the roof and back wall of cab, took a little time to seal the cargo light rubber base up good around the edges for a leak proof seal.
a littl paint on the manual steer colum and a blinker switch repair and it will be ready for install.
now to get the cab bushings and weather strip kit and get after the cab swap and cutting the shifter hole next.
Re: replacement cab. [Re: scratchnfotraction] #1470545
10/06/13 11:25 PM
10/06/13 11:25 PM
another pic.. i liky the champage
Re: replacement cab. [Re: scratchnfotraction] #1470546
10/06/13 11:26 PM
10/06/13 11:26 PM
some more looky see pics
Re: replacement cab. [Re: scratchnfotraction] #1470547
10/06/13 11:27 PM
10/06/13 11:27 PM
another one
Re: replacement cab. [Re: scratchnfotraction] #1470548
10/06/13 11:29 PM
10/06/13 11:29 PM
you liky the color??
better than 28 yrs of dirt and the ugly azz tan/rawhide/buff looking color it came with.
Re: replacement cab. [Re: scratchnfotraction] #1470549
10/06/13 11:30 PM
10/06/13 11:30 PM
now the white face gauges look like they fit better with the new dash color and black inside.
here is a shot of the 85 plug in the 91 cab hole...so no cutting...just to clear up the ? about the size when mixing yrs.
the hydro clutch MC does not alter the bulkhead [lug hole size.
Re: replacement cab. [Re: scratchnfotraction] #1470550
10/06/13 11:33 PM
10/06/13 11:33 PM
last one till next weekend update.
Re: replacement cab. [Re: scratchnfotraction] #1470551
10/07/13 01:47 AM
10/07/13 01:47 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
That champage would look much better in the 440 truck and get rid of that horrible red...
I am truckless..
Re: replacement cab. [Re: 340SHORTY] #1470552
10/07/13 03:14 AM
10/07/13 03:14 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It would look better with the yellow and red better with the black
Re: replacement cab. [Re: 76dodgeboy] #1470553
10/07/13 09:16 AM
10/07/13 09:16 AM
what??? yellow truck will look better with black dash door panels??
I will be getting back to the 440 truck once ol green is back up and running.
the red carpet is coming out for bed liner lower 1/2 of cab. and will be pulling the windsheild to chase a leak up there in a driving rain. so I will paint the dash and door panels on it.
it is gloss black inside now and the lower 1/2 will get bed liner...
so what color??
yellow dash/door panels? black? champage?
Re: replacement cab. [Re: scratchnfotraction] #1470554
10/07/13 07:01 PM
10/07/13 07:01 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Bees are yellow and black. So black.
Re: replacement cab. [Re: redraptor] #1470555
10/08/13 09:12 AM
10/08/13 09:12 AM
kinda what I was thinking. it is already that way exept for the red inside.
it kinda works as red and yellow are ok and red and black are ok so the 3 colors dont clash that mutch.
but one thing for sure..the wet carpet is got to go.
Re: replacement cab. [Re: scratchnfotraction] #1470556
10/20/13 11:14 AM
10/20/13 11:14 AM
got some wrenching done on the 85 truck coming apart.
it down for the count now till it starts going back together.
as allways thing snowball when you open the can of worms. i see now that I might as well pull the engine off the frame for some TLC.
it has 3 freeze plugs leaking, must have not replaced them 3 yrs agao when it went in the 85 truck.
so I figure I might as well degreese it,paint it up nice and orange, replace all the gaskets at this time.
then stick the 5 speed on the back of it and install it back in the frame.
Re: replacement cab. [Re: scratchnfotraction] #1470557
10/20/13 11:15 AM
10/20/13 11:15 AM
Re: replacement cab. [Re: scratchnfotraction] #1470558
10/20/13 11:16 AM
10/20/13 11:16 AM
done for today
Re: replacement cab. [Re: scratchnfotraction] #1470559
10/20/13 11:32 AM
10/20/13 11:32 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Moving right along!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
