Page 6 of 14 1 2 4 5 6 7 8 13 14
Re: replacement cab. [Re: 340SHORTY] #1470500
09/08/13 01:54 AM
09/08/13 01:54 AM
scratchnfotraction Offline OP
got the driprail/roof skin/pinchweld all tied back together by patching in a piecs and bending it so as to make the drip rail front edge.
got it welded up. did some grinding to smooth it,fingerd in some all metal to seal and fill it up good.
i think this will be better than any body sealer, it wont shrink and should seal the front pinch weld above and behind the top of window gasket.
this is where most of the rust/leaks come from on the roof IMHO.
not perfect but pretty good for a patch up before windshield goes back in.
now just hit it in the AM to smooth the all metal out some and it ready to patch up the roof skin across the front edge and fix a hole on the driver side top corner.
Re: replacement cab. [Re: scratchnfotraction] #1470501
09/08/13 01:55 AM
09/08/13 01:55 AM
Re: replacement cab. [Re: scratchnfotraction] #1470502
09/08/13 01:56 AM
09/08/13 01:56 AM
patching 101
Re: replacement cab. [Re: scratchnfotraction] #1470503
09/08/13 01:57 AM
09/08/13 01:57 AM
tie both side to patch by stitch welding in the flat piece
Re: replacement cab. [Re: scratchnfotraction] #1470504
09/08/13 01:57 AM
09/08/13 01:57 AM
Re: replacement cab. [Re: scratchnfotraction] #1470505
09/08/13 02:01 AM
09/08/13 02:01 AM
slow and steady with the stitch welding the grinder will fix the ugly.
Re: replacement cab. [Re: scratchnfotraction] #1470506
09/08/13 02:02 AM
09/08/13 02:02 AM
get r done
Re: replacement cab. [Re: scratchnfotraction] #1470507
09/08/13 02:02 AM
09/08/13 02:02 AM
bend and trim the front drip rail edge
Re: replacement cab. [Re: scratchnfotraction] #1470508
09/08/13 02:03 AM
09/08/13 02:03 AM
more hammer time more grinding starting to shpe up.
Re: replacement cab. [Re: scratchnfotraction] #1470509
09/08/13 02:06 AM
09/08/13 02:06 AM
man i need a lunch break soon.
Re: replacement cab. [Re: scratchnfotraction] #1470510
09/08/13 02:09 AM
09/08/13 02:09 AM
welds are almost ready to fill in with all metal.
trimed the driprail, so it has a front edge that lines up with the solid parts of the driprail that were not removed.
Re: replacement cab. [Re: scratchnfotraction] #1470511
09/08/13 02:10 AM
09/08/13 02:10 AM
done for the day
got one small piece to weld in the hole on driprail, i will get it tommarow.
Re: replacement cab. [Re: scratchnfotraction] #1470512
09/08/13 08:53 AM
09/08/13 08:53 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Cool fix. That would uber difficult if it weren't laying on the ground like that.
Re: replacement cab. [Re: redraptor] #1470513
09/09/13 10:08 AM
09/09/13 10:08 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Hey Scratch,
Are those panels any diff to weld on than the older automotive metals used back before 1980 or so? I thought I read that it is more difficult to weld on newer steel? What gauge metal mostly are you working with? What kind of welder?
Re: replacement cab. [Re: cudabitten] #1470514
09/15/13 01:37 AM
09/15/13 01:37 AM
got some more work done on the roof line today, very slow 1 day a weekend for progress. but the big hurdle is over, a little hand rubbing and it is ready for the gasket/glass.
pated up the holes left after sanding/grinding the rtv and rust out along the roof line/driprail.
finished filling it with all metal, last patch welded in the driprail edge.
trim long patches and stitch welded them across the front roof line. beded them in with all metal, needs some hand rubbing to smooth it out with some filler for a finished look.
Re: replacement cab. [Re: scratchnfotraction] #1470515
09/15/13 01:38 AM
09/15/13 01:38 AM
another pic
Re: replacement cab. [Re: scratchnfotraction] #1470516
09/15/13 01:39 AM
09/15/13 01:39 AM
and another
Re: replacement cab. [Re: scratchnfotraction] #1470517
09/15/13 01:40 AM
09/15/13 01:40 AM
welding 101 and grinding 202..?
Re: replacement cab. [Re: scratchnfotraction] #1470518
09/15/13 01:42 AM
09/15/13 01:42 AM
one more
Re: replacement cab. [Re: scratchnfotraction] #1470519
09/15/13 01:43 AM
09/15/13 01:43 AM
another
