Re: replacement cab.
[Re: scratchnfotraction]
#1470461
08/16/13 08:39 PM
08/16/13 08:39 PM
Posts: 15,487 Florida
scratchnfotraction
this little jem of a bracket will make it ez to go hydro clutch in something else. the 85 cab does not have the holes for the 4 bolts but could be welded right in place once a hole in the fire wall is cut. if a mech linkage set of pedels are on hand, they would just need a small piece welded up for MC hook up. with the correct v-6/v-8 hydro bellhousing the 833/833OD/5-speed can be used. been scratching around in the JY and have come up with a bracket/pedels from a truck. picked up a 94 DAK/AX-15 5 speed with its own 9 bolt hydro bell housing. free fit the budget, just hauled the rest off for the owner some recycler cash. looks like the folks over at dodge did not have to think too hard to come up with the hydro system upgrading the antique mech linkage.
[Re: basketcase]
#1470464
08/17/13 11:26 PM
08/17/13 11:26 PM
scratchnfotraction
lookin good Mike
rocker panel repair 101
Ace has me doing and watching small things as we do the first hole, 2nd smaller hole is mine to do after todays lesson.
small tricks save time, $$$, labor.
first cut rust out and square up the cuts.
then bend edges in slightly so patch welds in flush, giving a nice overlap on edges.
#1470466
08/17/13 11:29 PM
08/17/13 11:29 PM
scratchnfotraction
next up, a few small cuts then work the edge towards the inside a little.
#1470477
08/19/13 08:34 PM
08/19/13 08:34 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Your doing a great job. Fun to watch as I have some similar work to do on my 76. there are Basically no rocker panels left but I have replacements from the 84.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1470478
08/19/13 10:33 PM
08/19/13 10:33 PM
scratchnfotraction
thanks,I guess the biggest part of learning how to do it is doing it. I enjoyed doing all the body work on the 440 truck, and now more practice with the 85 truck. the more I do the better I should get as I fix my own rusted junk. helps having a paint & body man to guide me thru how it is done. i just follow his advice. he does a little but has me doing most of the cutting/drilling/welding/grinding for practice. I can tell you for sure that last saturday,if I was paying myself to do this work i would have fired me..
#1470479
08/21/13 11:15 PM
08/21/13 11:15 PM
scratchnfotraction
just a little sanding on the allmetal to smooth it out a bit, spray it and the bottom side is done up nice with a thick coat of bed liner. got a 2nd coat on the cab floor under foot.
