Electrical issue
#1470349
07/19/13 05:58 PM
07/19/13 05:58 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Had some electrical problems with my Duster, also had to replace a damaged cluster bezel. Got everything sorted put the dash back together and bolted the steering back up. Next day checked it and nothing was working, pulled the dash out again, then everything worked again, a few minutes later, nothing. I am thinking the problem lies between the fusible link and the ammeter, will check for continuity tomorrow. Fuses are all good under the dash. Any ideas ? cheers Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: Electrical issue
[Re: deaks]
#1470351
07/19/13 06:18 PM
07/19/13 06:18 PM
Posts: 6,516 Santa Cruz, California
Lefty
Any ideas ?
Rig up a wire with a 10 amp fuse inline and hook one end to the batt terminal on the starter relay. Then use the probe on the back of the ammeter, bulkhead, etc.
[Re: IMGTX]
#1470352
07/19/13 06:20 PM
07/19/13 06:20 PM
deaks
robin hood country
When it goes, nothing works, lights, motor, turn signal, wipers etc. That's what made me think, something between link and ammeter. I bypassed it all on my Dart but would just like to fix the Duster, rather than altering it all. Mick
[Re: deaks]
#1470353
07/19/13 06:23 PM
07/19/13 06:23 PM
deaks
robin hood country
Are you saying i should bypass the bulkhead plugs ? Mick
[Re: deaks]
#1470354
07/19/13 08:47 PM
07/19/13 08:47 PM
deaks
robin hood country
I think i've found the problem, when i fitted the dash cluster, i didn't tighten the ammeter cables tight enough and they were twisting, causing it to lose power. Thanks for your replies Mick
