Re: Alternator for electronic ignition
[Re: ditchdrift]
#1470223
07/19/13 01:35 PM
07/19/13 01:35 PM
RapidRobert
What Drift said, get an electronic reg & make sure it's making good ground contact. An electronic conversion will run with the OE electromechanical reg but the voltage spikes from how it operates ain't good for electronics plus they've been known to stick & full field the system.
[Re: RapidRobert]
#1470224
07/19/13 02:21 PM
07/19/13 02:21 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Ran them in 3 older Mopars.Now the 62 has full MSD as does my 65.My kid still runs the 62 alt and new style replacement electronic reg that looks like stock.Its been that way for 12 years.My 65 I have the square back and newer style reg.Been in for 13 years.Rocky
Chrysler Firepower
[Re: 68SportSatvert]
#1470226
07/19/13 06:42 PM
07/19/13 06:42 PM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
Depends on what type alternator you have, 1 field terminal, or 2 field terminals? The regulators will be different for the 2 types of alternators.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
#1470228
07/19/13 10:49 PM
07/19/13 10:49 PM
RapidRobert
What year vehicle? If it's a 69 or earlier with the "box" reg with a terminal on each side then yes (A) just get the electronic type replacement & someone on Moparts sells an electronic reg with a black cover that looks original if that is important & I think someone said the OE black cover will fit it for even more originality. If you have a later 2 field terminal alt with the (A) reg (OE electromechanical or electronic) just ground one of the alt field terminals. FYI if you have the later 2 field terminal alt & a '70 up "flat" reg in your stash you can trim the sides of it & redrill 1 mounting hole & it will nestle neatly into the firewall recess where the OE "box" reg once resided, just need the extra wire from the triangle reg connector to the 2nd field terminal on the alt (1 blue/1 green) & this may be the one you are referring to as looking like an ECU (it's ~half as thick as the ECU & has a triangle shaped plug in)
[Re: RapidRobert]
#1470229
07/19/13 11:40 PM
07/19/13 11:40 PM
therocks
Niles , Ohio
RR I think from his sig it looks like a 68.He needs the points looking type if it still has the one field wire alt.No need to run wires and drill holes with the electronic reg that replaces the old points type.Rocky
Chrysler Firepower
[Re: therocks]
#1470230
07/19/13 11:46 PM
07/19/13 11:46 PM
RapidRobert
Yes an electronic "box" replacement reg would take care of this real easy & from what I understand most of the replacement "box" regs are now electronic but I'm not sure on that.
#1470233
07/21/13 08:43 AM
07/21/13 08:43 AM
therocks
Niles , Ohio
Easy to spot the electronic reg that replaces the points type.Its almost flat.No need for a tall cover.You can take an old cover and use it on them though so it looks stock.Rocky
Chrysler Firepower
[Re: Joesixpack]
#1470237
07/21/13 12:45 PM
07/21/13 12:45 PM
therocks
Niles , Ohio
Joe thats the later style.Talking about the new replacements that look like the points type.The kids 62 is still running the OE alt with one.Been going strong for 14 years.Rocky
Chrysler Firepower
[Re: Twostick]
#1470239
07/21/13 02:25 PM
07/21/13 02:25 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
This is what I got to use with my electronic ignition.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1470240
07/21/13 02:40 PM
07/21/13 02:40 PM
therocks
Niles , Ohio
The reason to use the new electronic reg instead of points is because they charge much better.Typically you dont have the light flicker and dimming.Plus no points to stick or burn.Ive driven Mopars since the 60s.The replacement reg is one great part.They also charge better than the points.The reg in the picture might be one of the new ones that have the large cover.Look at the back.If there is a resistor its points type.The replacements attach just like OE but are maybe 1/2 to 3/4 inch high.Rocky
Chrysler Firepower
[Re: therocks]
#1470241
07/21/13 02:51 PM
07/21/13 02:51 PM
bboogieart
Lost and Spaced
I posted it because it is electronic.
[Re: therocks]
#1470242
07/21/13 05:00 PM
07/21/13 05:00 PM
Posts: 6,573 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
![](/ubbthreads/images/graemlins/iagree.gif)
I was just commenting in regards to an electronic ignition that my experience was that it ran just fine with the mechanical reg.
Kevin
[Re: Twostick]
#1470243
07/21/13 09:11 PM
07/21/13 09:11 PM
therocks
Niles , Ohio
Twostick most think you have to change the alt etc when you go to electronic ign.Im like you I know you dont.My kids 62 ran great for 2 years with the old mechanical reg.When it crapped out he went to the replacement electronic.I cant believe the 62 alt still works great and fires the now full MSd and his stereo.Bboo thats one of a few Ive seen that have the tall cover.Most are just almost flat.Rocky
Chrysler Firepower
