Cracked plastic door panel fix? #1470139
07/19/13 09:11 AM
07/19/13 09:11 AM
Midwest
jfb383 Offline OP
jfb383  Offline OP
Midwest
I have a couple of chips/cracks in my plastic door panel (woodgrain texture). Any suggestions about the best way to fix this? I'm thinking some sort of epoxy/filler and then paint entire panel to hide the patch.
Thanks!
Re: Cracked plastic door panel fix? [Re: jfb383] #1470140
07/19/13 10:26 AM
07/19/13 10:26 AM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
Eastwood sells various plastic repair kits, but I fear that anything you do will compromise the grain. The problem with two part resins is that they tend to be messy, but it'd be a cheap and strong fix. If you take your time, I'd say go for it with the epoxy and see what happens. At this point, it's already cracked.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: Cracked plastic door panel fix? [Re: BMChrysler68] #1470141
07/19/13 11:33 AM
07/19/13 11:33 AM
Fox River Grove, IL
HotRodRailroader Offline
Fox River Grove, IL
repair it from the back side and make sure you wipe off the excess as perscribed lightly dab some paint on front to match texture then paint the panel to blend it.
Re: Cracked plastic door panel fix? [Re: HotRodRailroader] #1470142
07/19/13 11:51 PM
07/19/13 11:51 PM
IN
ahy Offline
ahy  Offline
IN
Agree. Clean, scuff and repair the backside. Use a little fiberglass cloth with the "plastic friendly" epoxy for strength. I have used the SEM plastic paint system with good success for the visible parts (Eastwood).
