will it fit..converter question #1470023
07/18/13 07:18 PM
07/18/13 07:18 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Will a stock 727 converter from a big block 440, work in small block 727A trans..with 318
Re: will it fit..converter question [Re: dynamite] #1470024
07/18/13 07:47 PM
07/18/13 07:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes.. If the 440 is a forged shaft 440 there will be no problem. If it is a later cast shaft model just knock the weight off it and it then will work on an internal balanced engine like the 318.
Re: will it fit..converter question [Re: dynamite] #1470025
07/18/13 07:52 PM
07/18/13 07:52 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Yep.
This is the land of the free because of the brave
Re: will it fit..converter question [Re: MoparforLife] #1470026
07/18/13 08:30 PM
07/18/13 08:30 PM
scratchnfotraction Offline
done this more than once on my junk. it is adding the weight onto a TC that i have not done yet.
Re: will it fit..converter question [Re: scratchnfotraction] #1470027
07/18/13 09:07 PM
07/18/13 09:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You may need to use the larger flex plate..
I am truckless..
Re: will it fit..converter question [Re: scratchnfotraction] #1470028
07/18/13 09:50 PM
07/18/13 09:50 PM
Upper Midwest
Upper Midwest
Not hard to tack on a weight off another converter. Lay the two converters side by side with the offset lug in the same position and go from there. Done it many times and haven't had a problem with it yet.
Re: will it fit..converter question [Re: MoparforLife] #1470029
07/19/13 07:29 AM
07/19/13 07:29 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
It's from a forged steel crank 440..,so I don't have to do anything I guess... Thanks for all the help
