E body B body Hemi Kmember need help #1470014
07/18/13 07:07 PM
07/18/13 07:07 PM
maryland
rob_dirt Offline OP
rob_dirt  Offline OP
maryland
hello i have a Real 70 Hemi Cuda the k member is b body by all the pictures i have seen -- Now is E body different _________ from a B body My car was early and was the 23 Hemi Cuda built ( as i was told ) and if i use it will that effect the shaker hood by using the B body brackets and rubber mounts and set the bubble higher or lower Any help would be great
Re: E body B body Hemi Kmember need help [Re: rob_dirt] #1470015
07/18/13 07:15 PM
07/18/13 07:15 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I'm not sure about height but I was told the steering box mount had a different angle or something to that effect.
