06 Ram truck transmission. #1469841
07/18/13 03:14 PM
07/18/13 03:14 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
I have gotten a code that the rear solenoid pack needs to be replaced in the transmission . If this is the case is stock replacement the way to go or for a few extra dollars is there an aftermarket one I should get?
Could anything other than this pack throw this code?
Cheers Don.
Re: 06 Ram truck transmission. [Re: Dono] #1469842
07/19/13 08:05 AM
07/19/13 08:05 AM
Dono Offline OP
Dono  Offline OP
Nothing? With all this knowledge here nothing?
Don.
Re: 06 Ram truck transmission. [Re: Dono] #1469843
07/19/13 10:35 AM
07/19/13 10:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
545rfe? 48RE? Got the P code? Information always helps.....
Re: 06 Ram truck transmission. [Re: J_BODY] #1469844
07/19/13 03:22 PM
07/19/13 03:22 PM
Dono Offline OP
Dono  Offline OP
Behind a 5.7 hemi.
She dropped a T0700 then a P0750.
I pulled the + off the battery and turned the key on for a few sec's then off and put the + back on. Been fine all day now with about 70Km after.
Fluid level is fine if seemed kinda high on the dip stick for the hot level when it was hot. Nice an clean did a filter and fluid on her 60,000 km ago.
Cheers Don.
P.S. forgot to add that I run a Bully dog triple dog on this truck. I run her in the mid range setting. I don't know if the tuner adjusts any of the shift pressures. I can only adjust the shift RPM and speedo with tire size change.
Re: 06 Ram truck transmission. [Re: Dono] #1469845
07/24/13 09:58 PM
07/24/13 09:58 PM
Calgary, Alberta
Turbo392 Offline
Turbo392  Offline
Calgary, Alberta
If the code comes back I would buy a stage II valve body from SharaDon Performance since it would need replacement.
2003 Dodge Ram 1500 Turbo / Meth Injected 6.4L Hemi (392)
