Re: Is Hotchkis TVS suspension really worth the money
[Re: MuuMuu101]
#1469781
07/20/13 04:27 PM
07/20/13 04:27 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Although the Scamp had a fairly stock drivetrain, it did have upgraded wheels and brakes that most likely played a big roll in the event.
Tires yes. Brakes I wouldn't jump to that conclusion. It was a very short course.
What brake did the scamp have. Look like 11" rotor on some sliding piston caliper (stock or mustang 2 piston?) The drilled rotor would be worthless on that short course.
[Re: autoxcuda]
#1469782
07/20/13 04:29 PM
07/20/13 04:29 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
How would 9-10" drums compare to that kit though? Did slant A-bodies come with front discs as an option at that time? Granted it is a short course, would it be long enough for brake fade to develop in drums? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MuuMuu101]
#1469783
07/20/13 04:49 PM
07/20/13 04:49 PM
autoxcuda
So Cal
Yes /6 were always available with disc since 1966. More likely to see a /6 with disc in a '72 than a '66 for sure.
But when you said upgraded brakes, I'm thinking Willwood or something. Might be just a common simple inexpensive Late A-body or F-body disc swap.
[Re: autoxcuda]
#1469784
07/20/13 08:28 PM
07/20/13 08:28 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
When I said upgrade, I meant something better than stock (implying/assuming most slants didn't have discs).
[Re: MuuMuu101]
#1469785
07/20/13 11:15 PM
07/20/13 11:15 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
Not too bad. We autocrossed and short tracked the 62 R&D B-Body on 10" drums all four corners for 2 years.
[Re: Fastback67]
#1469786
07/21/13 06:39 PM
07/21/13 06:39 PM
Posts: 5,337 the house on the left.
cogen80
Here's a couple of shots (one from video). Sorry, but it's the best I can do for you at the moment.
good looking car but its a hard angle to see how the rear end sits.
[Re: 71340vert]
#1469787
07/21/13 08:49 PM
07/21/13 08:49 PM
Posts: 2,432 NorCal
RylisPro
NorCal
http://www.youtube.com/watch?v=4SwRwY6pDdE If you watch this video it shows the Emax Chally going around cones. I just don't like the fact that the rear squats down and the front lifts up. You can notice it in the first 60 secs of the video. I'm going to make sure that doesn't happen when I install the TVS kit on my car. Other than that it looks good ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
[Re: RylisPro]
#1469788
07/21/13 09:14 PM
07/21/13 09:14 PM
autoxcuda
So Cal
What "looks good" and "is fast" are two different things.
I'd FIRST make sure your car was as fast as that one, THEN worry about how it looks like during an autocross.
That car has turned autocross times close to better that much more expensive Pro Touring cars from Detroit Speed and Engineering, Swartz, etc, etc.
I think because it's lowered with the natual fender skirt those cars have, it's look like the rear is low just standing still. It's just transfering weight to the rear on acceleration.
If the rear was jacked up 2-3" to start with and the rear compressed the same as in that video, you would not notice it. Even though it's compressing the exact same.
[Re: RylisPro]
#1469790
07/21/13 10:46 PM
07/21/13 10:46 PM
autoxcuda
So Cal
I dont know much about suspensions and am still learning, but doesnt the weight transfer to the rear lessen front grip? Can that phenomenon be alleviated in some way? No doubt the car is fast, just seems weird to me?
It's comming out of the corner and going generally straight. Doesn't need front grip. But needs to keep rear tires from spining.
Traction Circle or Friction Circle
http://www.youtube.com/watch?v=JjCcFsGLpaM
http://www.rapid-racer.com/driving.php#Car Traction Circle
[Re: RylisPro]
#1469791
07/22/13 10:11 AM
07/22/13 10:11 AM
Dan@Hotchkis
Controlling proper weight transfer is very important to car handling. Allowing the nose to come up generates rear traction while accelerating out of a turn. The front wheels are fairly straight and not doing much of anything at that time.
[Re: 71340vert]
#1469793
07/22/13 01:35 PM
07/22/13 01:35 PM
Dan@Hotchkis
In my original post, I guess I should have mentioned that this car is going to see a lot of daily driving. I just wanted to upgrade the car to a nice handling suspension. I've heard concerns about Hiem joints for daily use. Should I be concerned? The car has already been stiffened withXV Motorsport stiffening kit. Will have viper disc brakes up front and big Brembo brakes in back from SRT 8 jeep. New Hemi with Nag 1 trans. The price for the Hotchkis system from THmotorsport is a good price and will probably buy that especiallu if they will giver torsion bars in lieu of frame connectors that I already have. Can some one make a recommendation for shocks for me? I was thinking about Bilsteins. Also looking for a front wheel that will fit a viper 14.25 diameter rotor. Hopefully something in an 18 inch that's not too pricey.
Our Fox shocks are tuned to run with our system. Also, if you piece together the kit vs. Buying it out right (same price) you can exclude the subframe connectors and add the torsion bars.
[Re: mopardude318]
#1469795
07/23/13 03:35 AM
07/23/13 03:35 AM
autoxcuda
So Cal
as i was watching those videos, i couldnt help but have the "deer in the headlights" look...
uhhhhhhhhhhhh....WHAT???
I just drive the damn car. Ill buy a kit that works, and let someone else do all the mathematician mumbo jumbo, when puttin one together... then go ripping
I'm sorry. I couldn't find just a plain simple explanation that they teach in almost every track day driving school.
It's much simpler that that dudes math.
[Re: autoxcuda]
#1469797
08/02/13 11:56 AM
08/02/13 11:56 AM
Posts: 6 Johnstown, PA
fastbackmopar
Johnstown, PA
I'm running Wilwoods drilled and slotted kit on the front and 11" drums on the rear.
[Re: Fastback67]
#1469798
08/02/13 12:00 PM
08/02/13 12:00 PM
fastbackmopar
Johnstown, PA
To the original poster, the best example of the effectiveness of our system would be the autocross event we just did in Carlisle. A 72 Scamp that was bone stock with a 1bbl Slant six placed 1st in A-Body (by nearly 3 seconds) and 6th overall with nothing done to the car other than our TVS and shocks.
I saw that car at the show... I watched it on the track from above. I can't tell you how surprised I was when I went down to the field and actually looked at the car up close.... "Is this the same car that I just saw buzzing around the track?"... I found myself looking around the field for a similar looking car, because this little 6-banger couldn't possibly be the right one. ![](/ubbthreads/images/graemlins/laugh2.gif)
Way Cool! ![](/ubbthreads/images/graemlins/thumbs.gif)
Hopefully, I'll be out there next year with my ride.
Thank you for the kind words. I'm glad you liked it. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 71340vert]
#1469800
08/07/13 03:52 PM
08/07/13 03:52 PM
Posts: 233 NH
Fastback67
NH
They told me it might take a day or two longer to receive my parts because they were breaking up a kit.
It shouldn't matter really... every piece of the kit comes in it's own individual box anyway. At least, that's how mine arrived, one box at a time.
