Power to manual steering Dodge Diplomat? #1469684
07/18/13 08:51 AM
07/18/13 08:51 AM
fullmetaljacket Offline OP
Changing from power steering to manual steering on my Dodge Diplomat.
What manual steering box do I need and what steering pitman/idler arm?
Re: Power to manual steering Dodge Diplomat? [Re: fullmetaljacket] #1469685
07/18/13 09:24 AM
07/18/13 09:24 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If you can find one off an Aspen or Volare it should work. You can also extend your existing column out to make it work. You will need to find the coupler for the manual box at the bottom of the steering shaft. The splines are different manual to p/s.
...FAFO...
Re: Power to manual steering Dodge Diplomat? [Re: fullmetaljacket] #1469686
07/18/13 01:54 PM
07/18/13 01:54 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
i used a box from a '66 belvedere. pitnan off the bevledere worked and i built the shaft between the column and the box out of some junkyard steering column joints.
Re: Power to manual steering Dodge Diplomat? [Re: fullmetaljacket] #1469687
07/18/13 05:30 PM
07/18/13 05:30 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Firm Feel offers the coupler extension / spline adapter.
Rick
Re: Power to manual steering Dodge Diplomat? [Re: skicker] #1469688
07/18/13 06:00 PM
07/18/13 06:00 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Now thats a rare item!
Just about any mopar manual steering box will work, 62 up IIRC.
I believe MOOG K7100 is the pitman, idler is the same for power or manual.
Re: Power to manual steering Dodge Diplomat? [Re: nomore65BelvJim] #1469689
07/18/13 06:10 PM
07/18/13 06:10 PM
Thank you again fellas.
