flywheel question #1469530
07/17/13 09:37 PM
07/17/13 09:37 PM
waverly oh
rdowns Offline OP
rdowns  Offline OP
waverly oh
How can you tell if a small block flywheel is neutral or external balanced
Re: flywheel question [Re: rdowns] #1469531
07/17/13 10:33 PM
07/17/13 10:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
By the casting ##?? or reference pics..
I am truckless..
Re: flywheel question [Re: 340SHORTY] #1469532
07/18/13 01:29 AM
07/18/13 01:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
reference pictures , big and small block , internal and external balance 130 tooth wheels are all the same casting .
Re: flywheel question [Re: rdowns] #1469533
07/18/13 01:36 AM
07/18/13 01:36 AM
External have great big holes, 360 have three of them(2 inch diamterter and around 3/4 inch deep, if I'm remebering correctly) side by side on the outer edge of the flywheel on the starter side . Same thing on the 1972 and 1973 340 but smaller and maybe a little bit different location in relation to TDC on #1, maybe not
Re: flywheel question [Re: Cab_Burge] #1469534
07/18/13 03:24 PM
07/18/13 03:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The cast crank 340 only had a single balance hole and it's small enough to get confused with the typical mass balance holes unless you know the exact location.
Re: flywheel question [Re: John_Kunkel] #1469535
07/18/13 03:36 PM
07/18/13 03:36 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
