96 Caravan will stall while driving only no codes.
#1469434
07/17/13 06:22 PM
07/17/13 06:22 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I have a 96 Caravan with a 3 L engine. It will run all day not driving it, just letting it run in the driveway. Get in it and drive it and a block later it will stall like you turned off the key. Wait a minute and it will start and go again for another block. It is losing spark. The distributor and the coil and the crank sensor have been replaced to no effect. Whats going on? HELP!
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 96 Caravan will stall while driving only no codes.
[Re: HemiRick]
#1469435
07/17/13 06:42 PM
07/17/13 06:42 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My nephew had one that did the exact same thing.His was a 3.0 also.I played with the grounds and it fixed it for a while.Then it started doing it again.I played with it at home and the shop.Never did figure it out.I even went thru tons of pages on All Data and nothing.Rocky
Chrysler Firepower
[Re: Skeptic]
#1469439
07/17/13 07:36 PM
07/17/13 07:36 PM
HemiRick
Memphis
I would buy the wire problem if it happened when the engine is accelerating and torquing the engine, but the engine is quitting after you accelerate and are going a steady speed. I will brake torque it and flex the harnesses in the morning, I've got the battery disconnected now and am wanting it to forget everything it knows. Just had a friend over with his snap on 3500 scanner and it couldn't find anything....It did say the Fuel pump voltage while it was running was zero.....kinda strange.
[Re: AARCONV]
#1469441
07/17/13 10:53 PM
07/17/13 10:53 PM
HemiRick
Memphis
And how is the throttle plate causing the spark to fail?
I dont think this is something random like a bad connection, it will quit running very consistently after driving about 200 ft. Every time. Sit wait 30 seconds to a minute and spark returns and it will run for another 200 ft.
[Re: HemiRick]
#1469442
07/17/13 11:35 PM
07/17/13 11:35 PM
Posts: 905 SD
zrxkawboy
SD
Wow, things like this can be a real b!tch. I sympathize with you.
Because of everything you've tried, I wonder if it's going to come down to the PCM. Unfortunately, there's probably no good way to test that theory short of replacement.
It's Swifty! Swifty, you toad sucker!
[Re: HemiRick]
#1469443
07/18/13 12:43 AM
07/18/13 12:43 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
If you have an Android phone, you can download the app "torque" ($5), and get an ELM327 bluetooth OBD2 dongle ($15), and datalog all the sensors, drivers, etc., which may help you. I found a bad TPS in one minute on GF's Neon this way, no codes, but TPS voltage was fluctuating even with throttle held steady. Car was barely running, over-rich, etc.
Having said that, my money's on wiring / ground issues or bad SBEC.
Rick
[Re: AARCONV]
#1469447
07/19/13 12:58 PM
07/19/13 12:58 PM
HemiRick
Memphis
Because when it wont run/start it has no spark. Did you read my 1st post? I also noticed that when it dies the speedometer goes to zero immediately, so it losing its signal too. Also the trick on this page http://www.allpar.com/fix/codes/sensors/auto-shutdown.html to backfeed power thru the pos side of the coil makes no diff.
