lower dash pad removal 69 gtx #1469333
07/17/13 04:56 PM
07/17/13 04:56 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
I need to remove my instrument cluster to replace the tach on my 69 Gtx looks like the lower dash pad has to come off to get the cluster out.How do I do that?
Re: lower dash pad removal 69 gtx [Re: gts1] #1469334
07/17/13 05:01 PM
07/17/13 05:01 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
You can do it without removing the dash pad. I had my tach rebuilt so had to remove it. Remove the ashtray and holder and you should be able to get to the screws holding the tach in place... if you have small hands.
Have some band aids handy for all the cuts and scrapes you will suffer.
Re: lower dash pad removal 69 gtx [Re: moparcanuk] #1469335
07/17/13 07:54 PM
07/17/13 07:54 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I agree. Taking the radio out helps with space too.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
