2004 RAM 2500 4 x 4 - Front Drive Shaft #1469115
07/17/13 08:57 AM
07/17/13 08:57 AM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
Is there anything to lubricate on a factory front drive shaft in a 2004 model?
I've seen a couple of you-tube videos for lubing front drive shaft on a 2008, but transfer case u-joint appears to be different on a 2004.
Thanks.
Re: 2004 RAM 2500 4 x 4 - Front Drive Shaft [Re: 74Charger] #1469116
07/17/13 09:03 AM
07/17/13 09:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is there a slip joint that needs to be lubed ?
Re: 2004 RAM 2500 4 x 4 - Front Drive Shaft [Re: JohnRR] #1469117
07/17/13 04:01 PM
07/17/13 04:01 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
A youtube video shows a section of the double u-joint at transfer case being lubed, but mine appaears different than a 2008. IDK
