Re: brakes locking up
[Re: MILFORD MOPARS]
#1468853
07/16/13 05:32 PM
07/16/13 05:32 PM
Challenger 1
Cincinnati, Ohio
I'm pretty sure it is not the fluid getting hot and expanding.
Try loosening the 4 nuts that hold the master cylinder to the booster and see if that will allow the brakes to release.
Be sure the drums brakes are adjusted properly and that you have the shoes installed properly.
#1468854
07/16/13 09:58 PM
07/16/13 09:58 PM
RapidRobert
seperate the M/C and the booster & measure how much clearance you have between the round nub on the end of the pushrod & the bottom of the piston recess (want ~.060"). For a quick check shorten it & see if that fixes the problem. If you get too much clearance you wont have enough pedal reserve (pedal too close to floorboard when brakes are applied)
#1468857
07/24/13 03:01 PM
07/24/13 03:01 PM
Challenger 1
Cincinnati, Ohio
yep tried that .tti tells me my m.c. is not venting??? I did shorten the rod and it did not help.maybe the booster is not releasing after it gets hot?? could the pads be installed backwards and create heat?
Yes
[Re: Challenger 1]
#1468858
07/24/13 03:37 PM
07/24/13 03:37 PM
Posts: 9,316 SoCal
68HemiB
SoCal
FYI:
In drum brakes, the shoe with the longer and/or darker friction material goes toward the rear.
The shoe with the shorter and/or lighter friction material goes toward the front.
Down to just a blue car now.
[Re: 68HemiB]
#1468859
07/24/13 03:44 PM
07/24/13 03:44 PM
RapidRobert
I still think the prob is in either the booster or the M/C especially if all 4 corners are locking
