Dually Tire Wear
#1468417
07/15/13 07:15 PM
07/15/13 07:15 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Outside tires are wore down further than the insides. Is this normal?
I am going to swap them around to even out the wear.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Dually Tire Wear
[Re: Rug_Trucker]
#1468418
07/15/13 07:50 PM
07/15/13 07:50 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Have you had it for awhile?? Wondering if someone took them off the front and put them on the rear...
I am truckless..
[Re: 340SHORTY]
#1468419
07/15/13 08:47 PM
07/15/13 08:47 PM
Rug_Trucker
I bought it in '08. I have put 47K om it. Steel rims. The tires on the back are Michelins. They were on it when I got it. The wear is even.
[Re: hp383]
#1468423
07/16/13 12:18 AM
07/16/13 12:18 AM
Rug_Trucker
Im a little confused, you said the outside tires were worn down more, but then said the wear is even?
Yes, as far as each tire. My front end needs some work. The fronts that were on there were pretty bad. One had a broke belt.
BTW 383 you make some valid believable points ![](/ubbthreads/images/graemlins/thumbs.gif)
