Re: '67 Satellite Disc brake upgrade HELP
[Re: dynorad]
#1468166
07/15/13 05:49 PM
07/15/13 05:49 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
the steel lines are attached to the frame rail behind the spindle on both the '70 Dart and the '67 Satellite. The '73 B-Wagon are attached forward of the spindles with the Brake Calipers behind the spindle. *It seems where the steel lines attach to the frame determines where it's best to install the calipers.* steel line to the rear, caliper to the front and vise a versa right??? you would think you might encounter clearance problems if the hoses/calipers are on the same side of the spindle as the steel lines are fixed to the frame rail? now i'm very confused
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1468168
07/15/13 06:01 PM
07/15/13 06:01 PM
Copper Dart
I like the part of the article that mentions using an adjustable rear proportioning valve just aft of the OEM and keeping the stock one in place for the Brake Warning lamp circuit. This Mopar site and it's contributors are PRICELESS for the classic car enthusiast <sp>. Thanks Moparts
[Re: Copper Dart]
#1468169
07/15/13 07:43 PM
07/15/13 07:43 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Yes you have that thinking right BUT the factory made a change to that line of thinking in the early 70's.
The original disc brake setup on both your dart and 67 had the steel line on the rear AND the caliper mounted to the rear , if they were mounted on the front they would have hit the swaybar endlink at least on the B body, A body was mounted in same spot but lower, interference ??
[Re: dynorad]
#1468170
07/15/13 07:44 PM
07/15/13 07:44 PM
JohnRR
A gulag near you.
When I did my 67 I fabbed a new brake hose mount up at the front and ran a short piece of brake line from there to the stock mount, thus allowing a stock flexible hose to be used.
I like that idea , the tab could be removed if one wanted to return to stock .
[Re: Copper Dart]
#1468171
07/15/13 07:48 PM
07/15/13 07:48 PM
JohnRR
A gulag near you.
Tell me if I got this right. Keep the A-Body spindles for the Dart. Remove the slider caliper adapters, calipers, dust shields and rotors and replace them with the Adapters, calipers, dust shields and the rotors from the '73 wagon? So the spindles will be correct for the A-body adding the bigger brakes (pin type) from the wagon. A little more work but sounds good. The bearings and hubs same? This is to keep the shorter spindle on the Dart and the 3/8 taller one for the Satellite? ricky
You do not have to swap the splash shields unless one is uglier than the other , the splash shields are the same even though one rotor is larger than the other.
I don't know how tough it will be to find a pin type caliper in the configuration you need. Dr. diff repopped the larger caliper adapter for the slider caliper.
Bearings are the same , the rotors on both should be one piece and the only difference is the diameter of the disc itself.
[Re: Copper Dart]
#1468172
07/15/13 11:08 PM
07/15/13 11:08 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
<snip!>
Mount the calipers to the rear of the spindle right?
If you mount the calipers on the rear, on a car with the frame hydraulic hose brackets also on the rear, there's no correct way to hook up a hose. The brake hose should cross the steering axis! No matter what you do, check for going taut, rubbing, snagging, etc. and full steering ock L/R, full jounce, full rebound, and all combos.
You can move the frame bracket to the front (new hardlines, etc.), but then it isn't quite a "bolt on" any more.
Remember that the bleeder screw must always be at the top -- you wouldn't believe how often that "detail" is overlooked.
Rick E.
[Re: Rick_Ehrenberg]
#1468173
07/15/13 11:27 PM
07/15/13 11:27 PM
moparpollack
Lil Herman
Lil Herman
85086
<snip!>
Rick E.
I thought Dr.Diff had it worked out with a 68 GTO hose that worked with the rear mount calipers?
#1468175
07/16/13 09:03 AM
07/16/13 09:03 AM
JohnRR
A gulag near you.
<snip!>
Rick E.
Rick maybe you need to clarify a part of the statement to say "with the single piston caliper"?? As you know the 66-69 B bodies had rear mounted hardline and caliper from the factory, same with pre 73 A bodies ... it seemed to work ??
[Re: JohnRR]
#1468176
07/16/13 09:06 AM
07/16/13 09:06 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
I agree make sure the bleeders are up.After all the years as a tech I was 1/2 blind doing my change.Took me about 1/2 gallon brake fluid to find I had the bleeders down.Rocky
Chrysler Firepower
[Re: therocks]
#1468177
07/16/13 12:49 PM
07/16/13 12:49 PM
Copper Dart
I don't have a sway bar for either the '70 Swinger nor the '67 Satellite. I will try to mount the calipers toward the front (opposite of the fixed steel line mounting to the frame rail). If I up-grade later to a sway bar I will be better prepared for fitment issues. For now getting both cars back on 4 wheels with the Discs installed and driving is my goal. Can someone explain why I must use the spindles from the '73 B on the '67 B and the '74 A on the '70 A? Just asking, what difference does it make which car ends up with the 3/8" taller spindles?
[Re: Copper Dart]
#1468179
07/16/13 01:18 PM
07/16/13 01:18 PM
JohnRR
A gulag near you.
Putting the calipers to the front will not make you better prepared for fitment issues unless your goal is to have fitment issues if you decide to install a factory style , year correct , sway bar of either vehicle and unless the 70 A body is just going to be a drag race only , driven in a straight line vehicle you be wise to put a swaybar on it .+
It really doesn't matter which car you put the taller spindles on, you asked and I told you what I would do.
[Re: DoctorDiff]
#1468180
07/16/13 01:25 PM
07/16/13 01:25 PM
Copper Dart
Not worrying about caliper placement, if you remove the lower ball joints, can the spindles be used on either side?
[Re: Copper Dart]
#1468181
07/16/13 02:32 PM
07/16/13 02:32 PM
JohnRR
A gulag near you.
Yes
