Np205?? #1466940
07/12/13 02:56 PM
07/12/13 02:56 PM
Iowa
76dodgeboy Offline OP
Iowa
Finally got an NP205 . My question is where can I get a new coupler? For a gas motor. Also a basis kit to go through it. Thanks
Re: Np205?? [Re: 76dodgeboy] #1466941
07/13/13 12:04 PM
07/13/13 12:04 PM
Terre Haute, Indiana
bgilbert Offline
bgilbert  Offline
I get most of my drivetrain parts/kits from www.zbag.com and sometimes ebay. Zbag would be your best bet for the coupler though.
85 D350 crew with 90 Cummins 6BT Getrag 3.07 93 D350 single cab Getrag 3.54 74 W300 360 4 speed 4.88 70 front/rear
Re: Np205?? [Re: bgilbert] #1466942
07/13/13 02:20 PM
07/13/13 02:20 PM
Iowa
Iowa
Thanks. I checked ebay but want to try and find one in my price range(cheap aZZ)
Re: Np205?? [Re: 76dodgeboy] #1466943
07/13/13 04:16 PM
07/13/13 04:16 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
You need the adapter? From the case to the trans? It looks like it has the slip coupler on it? There is a truck junkyard in Ohio that has all kinds of old and new stuff if you want to try for shipping?
Auto or stick?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Np205?? [Re: OhioMopar] #1466944
07/13/13 05:52 PM
07/13/13 05:52 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Did it come from behind a 5 speed getrag?otherwise the automatics used the smaller gas input
Re: Np205?? [Re: 500ciDuster] #1466945
07/13/13 06:22 PM
07/13/13 06:22 PM
Iowa
Iowa
You do realize the "Adapter" is also the Tailshaft when on a 4wd tranny.
Was ibm and 80s gasser with auto to my knowledge. Plan on a 4spd going in front of it
Re: Np205?? [Re: 76dodgeboy] #1466946
07/13/13 10:02 PM
07/13/13 10:02 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Yes, the 208-435 adaptor should work for you if you use a 1980 and up 435, 79 and older automatics have the wrong length output shaft which always made think the manuals may have been the same because they were made for the 203's
Re: Np205?? [Re: 500ciDuster] #1466947
07/13/13 10:08 PM
07/13/13 10:08 PM
Iowa
Iowa
I know. I only asked about a kit and coupler source. Any adapter on a Chrysler Gas trans should work
Re: Np205?? [Re: 76dodgeboy] #1466948
07/13/13 10:15 PM
07/13/13 10:15 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Sure,was just trying to help. I did an auto to 4-speed with a 205(gas) in my 85 and used a 1980 435+adaptor and the coupler was ok from the auto.
Mitch
Re: Np205?? [Re: 500ciDuster] #1466949
07/13/13 11:01 PM
07/13/13 11:01 PM
Iowa
Iowa
Thanks. The coupler I have seems usable but not sure if it will handle a 440/4spd D60s with 4.88s and 37" tires. The spines look a little wore. Even if it goes in my wife truck with a pretty stick 400/727 it'll still have 37s with 4.10s though. I want a divorced unit. One at local jy but short on cash for it
Re: Np205?? [Re: 76dodgeboy] #1466950
07/14/13 04:06 PM
07/14/13 04:06 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
We ran that setup behind a 440 and pulled in the bone stock classes, broke some U-joints but everything else held up.
Mitch
