My new drag radials&wheels. **New Fitment pics added...
#1466888
07/12/13 02:53 PM
07/12/13 02:53 PM
Posts: 10,191 A Red State
SNK-EYZ
A Red State
I got a set of Mickey Thompson 275/60R15 drag radial pros a few weeks ago and was trying to decide what wheels to run them on. I finally decided and they arrived Tuesday, I had them mounted and balanced on Wednesday. I finally took pics last night so here they are. ![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/Photo150_zps4b532af0.jpg) ![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/Photo151_zpsee9b5c85.jpg) ![](http://i471.photobucket.com/albums/rr72/SNK-EYZ/Photo152_zps1acf2320.jpg) The wheels are 15 x 8's, this is the biggest combo that will fit in my wheelwells.
Re: My new drag radials and wheels!!!
[Re: Ian]
#1466895
07/13/13 01:11 AM
07/13/13 01:11 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I really like your tire / wheel combo. Do you have any photos of them on the car. I recently managed to squeeze 295/55R15 MT Street ETs on 15" x 10" steelies behind my "stock wheel well" '68 Roadrunner.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#1466896
07/13/13 01:55 AM
07/13/13 01:55 AM
SNK-EYZ
A Red State
Yes, they're the Summit wheels. 15 x 8 with a 4.5 inch backspacing.
They're going on my 67 Satellite.
I'm planning on doing the test fit with the stock rear end tomorrow, probably gonna be close on the fender lip.
I should have the dana 60 soon (maybe next week) and it was made 1 inch narrower overall (1/2" on each side).
If I roll the fender lips I'll have more room also.
From all the measuring I did to plan it out it will fit best that way (1/2" in on each side). It should give me 1/4" clearance spring to tire sidewall (which is a fixed distance) and clearance to the stock fender lip.
I did a trial fit with one tire on a 15 x 7 wheel (stock 4.25 backspacing) and it fit fine in the wheel well but was pulling the sidewalls in too much for me. It was puffing out the center of the tread about 1/8th inch at 18 psi.
I did a trial fit on a 15 x 8 wheel (4.25 backspacing) and it hit too hard on the fender well outer lip. The lips haven't been touched in any way "yet" (stock, not rolled or trimmed).
These are only 1/4 more backspacing so I'm not sure if they'll fit and clear the fender lip with the stock width rear end.
I'll post how it fit's with the stock rear end tomorrow.
From all my calculating it looked like a 15 x 8 wheel with a 5 inch backspacing would be the best fit on a stock width 67 rear end but a wheel with 4.75 backspacing would probably work too.
[Re: SNK-EYZ]
#1466897
07/13/13 02:00 AM
07/13/13 02:00 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
275's are usually right on the edge with the 66 / 67 cars. With the slightly narrower Dana, they should fit good and look great! Nice Choice, I've looked at the summit wheels for a long time, nice to see a set with tires mounted. They look great!
[Re: StealthWedge67]
#1466898
07/13/13 11:55 AM
07/13/13 11:55 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Let us all know how good they hook,I am looking at buying a set!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: My new drag radials and wheels. **Fitment pics added...
[Re: SNK-EYZ]
#1466904
07/14/13 06:09 PM
07/14/13 06:09 PM
moparpollack
Lil Herman
Lil Herman
85086
As a owner of a 67 coronet I feel your pain. How much gas is in the tank when you put the wheels and tire on? Mine wheels and tires fit until extra weight got put on. They look great but they don't fit my car. Hopefully the Dana will give you extra room. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rowin4]
#1466906
07/14/13 08:11 PM
07/14/13 08:11 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You want about 5/8" minimum to not have any worries for cruising around city streets. If compromises need made, then at least have it be a nice flat surface and nothing like wheel opening trim. Tires can "take" some rubbing, like pulling into a driveway at an angle, at low speeds and be fine forever. Just make damn sure nothing touches like after a pass and you let off the gas at 120.
Mopar to the bone!!!
[Re: 72Swinger]
#1466907
07/15/13 12:50 AM
07/15/13 12:50 AM
SNK-EYZ
A Red State
As I had stated earlier the dana will be 1 inch narrower overall, 1/2 inch in on both sides. The springs are in the stock location. That's the problem with 66/67's, you can't move them into the frame rails and run tailpipes in the stock location. Much less the 3 inch TTI tailpipes that my car has. They run under the rear frame rails. Dan moved the spring perches in on the axle 1/4 inch on each side from the stock location on the dana. I hadn't planned on that, but he says he done it before and it will help on the clearance to the springs and works fine and it's no problem lining up the rear end on the spring centering pins. The distance from the springs to the tire is a fixed (non moving) distance. The fender lips are the ones I'm worried about. If I have to roll the fender lips or trim them I will. I'm gonna wait till I have the dana in the car to see what the final clearance is first. It's still an original 18k mile unrestored body so I hate to cut stuff if I don't have to. But I will if I have to. ![](/ubbthreads/images/graemlins/laugh2.gif)
