Re: 727 explosion [Re: Leon441] #1466520
07/11/13 08:18 PM
07/11/13 08:18 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Turbo 400's blow up to. The difference Chevy people listen to each other and will not dare run with without the safety provisions on their 400's.
Why in the world would anyone run a stock drum in a 727 is beyond me. Then if you did and it blew up I personally would count my blessings and not say a peep. Kind of like if I got wild and crazy drunk one night and decided to drive the race car down the road naked and it caught fire and burnt up my privates. Would not tell anyone.
If you bought the stuff and was told it had a billet drum when it in fact did not. Sorry for your loss.
Leon
So will T350s. Saw a fellow in a blown alcohol Camaro kill one. Tiny pieces and oil everywhere. He went for an amberlamps ride.
Re: 727 explosion [Re: CMcAllister] #1466521
07/11/13 08:42 PM
07/11/13 08:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A good Friend od mine destroyed a clutch flight at Norwalk in a front engine high 8 second dragster. The case spun between his legs and luckily one of the tranny lugs bent the chrome moly cage but stopped it from spinning. A piece of the case hit a guy in the stands in the head. another guy passed out when he saw the blood and fell in the stands. When the trannt blew it ripped 3 morse cables going to the engine like they were toilet paper. The tranny blanket looked like ground up fiberglass. Very scary day.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 explosion [Re: Plymouth340] #1466522
07/11/13 08:48 PM
07/11/13 08:48 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You pedaled it while still in low gear.. right...
glad your ok
NO...broke just as I left the line..foot to floor
Did the engine free rev just before it blew? Was there any indication or something seeming not right just before the boom?
Re: 727 explosion [Re: CMcAllister] #1466523
07/11/13 08:50 PM
07/11/13 08:50 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Leon
Out of curiosity, what blows/causes the explosion on the TH350 and TH400?
Re: 727 explosion [Re: emarine01] #1466524
07/11/13 08:56 PM
07/11/13 08:56 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Here's an explanation of a Torqueflite drum explosion.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: 727 explosion [Re: Sport440] #1466525
07/11/13 09:00 PM
07/11/13 09:00 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
glad your ok
Nope. made one pass and all was good.second pass car went about two feet and boom !!!
Re: 727 explosion [Re: Plymouth340] #1466526
07/11/13 09:14 PM
07/11/13 09:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
glad your ok
Out of curiosity do you back up after your burn out..
you need 4 or 5 feet to set the sprag minimum(going
forward)... to be honest I'm not sure if you have
to do the same thing after being in neutral but I
always give it 5' or more
Re: 727 explosion [Re: MR_P_BODY] #1466527
07/11/13 09:20 PM
07/11/13 09:20 PM
CEDAR RAPIDS
CEDAR RAPIDS
glad your ok
did not backup..did the burn out and everything the same like I have for 25 years of using a trans brake
Re: 727 explosion [Re: Plymouth340] #1466528
07/11/13 09:40 PM
07/11/13 09:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Check your rear gears. When my buddies went right after launch we found teeth gone from the ring gear. That's what lit the fuse in our case.
Re: 727 explosion [Re: J_BODY] #1466529
07/12/13 03:34 AM
07/12/13 03:34 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Just redid a 904 for a friend that had this exact same thing happen, rolled the sprag,broke the case and cleaned the splines out of the planitary,,but did not explode the drum. so yes check the rear end.
Re: 727 explosion [Re: dartman366] #1466530
07/12/13 08:03 AM
07/12/13 08:03 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
The Guy I bought my 70 RR from Had his wife racing the car at the local track and grenaded the trans at the line.
He did not have the shield on the trans and when it went the ambulance took her away.
I had to replace the trans tunnel and a portion of the drivers floor.
Very scary business to say the least.
The moral is don't race without the correct safety equipment in place.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 727 explosion [Re: Leon441] #1466531
07/12/13 11:46 AM
07/12/13 11:46 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Not really. TH400's came with two different sprags. The HD one is twice as strong as the other but if either one fails the trans loses 2nd gear. The direct drum does explode in TH400's but that's from either shifting into neutral at the finish or shifting into 2nd with a manual valve body. If you leave it in third and coast/brake down it's fine.
I ran mid 10's for a year with a TH400 out of a junkyard with nothing but a new filter. They are tough trans. When left fully automatic they are very easy to tweak the shift points with wights and springs behind an access plate. They are heavy, soak up HP but they are tough. I bought an adapter bellhousing to start running them over 727's. Cheap cores, cheap parts.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: 727 explosion [Re: d7cook] #1466532
07/12/13 01:04 PM
07/12/13 01:04 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Is a 727 with a trans brake have more of a chance blowing the drum apart? I just foot brakeit but was thinking of going with a brake. I have a stock drum in my car and always worry about it but havent had any issues in the last 4 years. I also worry about the 8 3/4 but now that I have around 100 passes on it and it still looks like new I am starting to think its good to go. My car only weighs 3800 lbs and only 60' in the high 1.4's. I am very carefull to do 2nd gear burnouts only and it never spins and if it does I will be shifting not pedalling it.
67' charger 499 RB 10.57 at 127
Re: 727 explosion [Re: Sport440] #1466533
07/12/13 01:14 PM
07/12/13 01:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With high-stall converters the brief flareup in rpm often isn't noticed by the driver. I've known some veteran drivers who, even when they sensed the flareup, couldn't get out of the throttle quick enough to save the trans.
Re: 727 explosion [Re: Sport440] #1466534
07/12/13 01:45 PM
07/12/13 01:45 PM
CEDAR RAPIDS
CEDAR RAPIDS
glad your ok
I think it might have free rev just before it blew. it all happen so fast
