Re: 727 explosion
[Re: Plymouth340]
#1466522
07/11/13 08:48 PM
07/11/13 08:48 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
You pedaled it while still in low gear.. right... glad your ok
NO...broke just as I left the line..foot to floor
Did the engine free rev just before it blew? Was there any indication or something seeming not right just before the boom?
Re: 727 explosion
[Re: Sport440]
#1466525
07/11/13 09:00 PM
07/11/13 09:00 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
Nope. made one pass and all was good.second pass car went about two feet and boom !!!
Re: 727 explosion
[Re: Plymouth340]
#1466526
07/11/13 09:14 PM
07/11/13 09:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Out of curiosity do you back up after your burn out.. you need 4 or 5 feet to set the sprag minimum(going forward)... to be honest I'm not sure if you have to do the same thing after being in neutral but I always give it 5' or more
Re: 727 explosion
[Re: MR_P_BODY]
#1466527
07/11/13 09:20 PM
07/11/13 09:20 PM
Plymouth340
CEDAR RAPIDS
did not backup..did the burn out and everything the same like I have for 25 years of using a trans brake
Re: 727 explosion
[Re: J_BODY]
#1466529
07/12/13 03:34 AM
07/12/13 03:34 AM
dartman366
Mt. Vernon, Ohio
Check your rear gears. When my buddies went right after launch we found teeth gone from the ring gear. That's what lit the fuse in our case.
Just redid a 904 for a friend that had this exact same thing happen, rolled the sprag,broke the case and cleaned the splines out of the planitary,,but did not explode the drum. so yes check the rear end.
Re: 727 explosion
[Re: dartman366]
#1466530
07/12/13 08:03 AM
07/12/13 08:03 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The Guy I bought my 70 RR from Had his wife racing the car at the local track and grenaded the trans at the line. He did not have the shield on the trans and when it went the ambulance took her away. I had to replace the trans tunnel and a portion of the drivers floor. Very scary business to say the least. The moral is don't race without the correct safety equipment in place.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 727 explosion
[Re: d7cook]
#1466532
07/12/13 01:04 PM
07/12/13 01:04 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Is a 727 with a trans brake have more of a chance blowing the drum apart? I just foot brakeit but was thinking of going with a brake. I have a stock drum in my car and always worry about it but havent had any issues in the last 4 years. I also worry about the 8 3/4 but now that I have around 100 passes on it and it still looks like new I am starting to think its good to go. My car only weighs 3800 lbs and only 60' in the high 1.4's. I am very carefull to do 2nd gear burnouts only and it never spins and if it does I will be shifting not pedalling it.
67' charger 499 RB
10.57 at 127
Re: 727 explosion
[Re: Sport440]
#1466534
07/12/13 01:45 PM
07/12/13 01:45 PM
Plymouth340
CEDAR RAPIDS
I think it might have free rev just before it blew. it all happen so fast
