10 sec small block 340's #1465713
07/10/13 12:47 AM
07/10/13 12:47 AM
western PA
Sb Valiant Offline OP
western PA
I just don't see this topic brought up enough or talked about alot. Maybe just not to many people have good running small blocks. I would like to see your stock stroke 340 combo. If not stock stroke a very basic stroker. Would like to even see a very basic simple stock stroke 340 combo running 10's if anyone had one they would like
to share!?!? Besides the engine combo if anyone would like to share about the car itself and all the tricked out parts you might be using in the suspension
or transmission/converter. Lite weight 904 trans with aluminum parts and low gear sets with roller sprags. Just curious and would love to hear any info for a guy like me who just can't simply afford what alot of people are doing! Thanks Brock
Re: 10 sec small block 340's [Re: Sb Valiant] #1465714
07/10/13 01:28 AM
07/10/13 01:28 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
back in 90 built a .030 trw domed stock stoke loosely machined crank and bore clearances stock rods machined on tight side for bearing clamping, o-ringed, usead a narrow rear main bearing, tubed block, external oil lines, X heads I ported, roller .275 @ 050 .628 lift, h/s rockers victor intake 2 in headmans on adapter plates, in 2700 72 duster 5.13 ladder bar 8in turbo action manual v/b 727, 31x13x15 slicks on race fuel 830 carb ran 11.30s on 750alky 10.90s, even with a near stock 340 same car ran 12.20s, it was just a good built car.
Re: 10 sec small block 340's [Re: Cheatham] #1465715
07/10/13 01:36 AM
07/10/13 01:36 AM
western PA
western PA
Awsome thanks for the share Cheatham!
Re: 10 sec small block 340's [Re: Cheatham] #1465716
07/10/13 01:45 AM
07/10/13 01:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not all that hard to do, really: back in the mid-70s my Duster (the Ed Hamburger car) was the first SS/IA car in the 10s and had the NHRA record for a while.
Mid-late '90s with a 358" 340, iron W2s, Crane flat tappet, basic 904, 5.38 gear & 13x31 tire, modified SS springs, I was running 10.50s in decent air.
Now 368" R1 block, Batten W2s, Comp roller, 6000 stall, otherwise pretty much the same, low 10s @ 3500' DA with an 850 Holley and no real tuning, through race bullet mufflers.
By today's standards, nothing really trick: Jack Arnew control arms and a couple of old SS tricks is all. Did have to add wheelie bars after a 300' ride on the rear bumper, though.
Re: 10 sec small block 340's [Re: topside] #1465717
07/10/13 02:01 AM
07/10/13 02:01 AM
western PA
western PA
topside thats way cool about back in the 70's and holding a NHRA record! Thanks for the info! I love hearing all these old combos/present combos and stories!!!
Re: 10 sec small block 340's [Re: Sb Valiant] #1465718
07/10/13 09:13 AM
07/10/13 09:13 AM
BPE Offline
BPE  Offline
Vic's S/ST3040 stock stroke 340, 10.28 to 1,factory cast iron heads that he ported on pump gas. This was the first 9 sec. pass he made, eventually I think it went 9.78 in better air. 904 with a 6250 convertor, 557 gear and a 31" tire.
http://www.youtube.com/watch?v=XUqBDDtKYkk
Rod
Re: 10 sec small block 340's [Re: BPE] #1465719
07/10/13 09:40 AM
07/10/13 09:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Rod, how much did that car weigh?
Re: 10 sec small block 340's [Re: BPE] #1465720
07/10/13 09:46 AM
07/10/13 09:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running 10.1s with the engine thats going into
my Rampage now... was in the race car as my back up
engine... its a 10.6:1 with iron W-2s home ported..
.640/.640 roller, home made headers... back then it
was a stock stroke with 4.88 gears and 31" tire... now
its a 3.79 stroke and runs 9.50s in the same car
Re: 10 sec small block 340's [Re: MR_P_BODY] #1465721
07/10/13 12:28 PM
07/10/13 12:28 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
One of the better running combo's I have seen was a stock stroke 360.
3200 pound 71 cuda, 727 trans, 8 inch convertor, stock eddies, 525/305 comp hydraulic cam, race demon, about 12 to 1 compression with 1 7/8 headers.
ran 10.90's at 121/122 or so, thought that was impressive at that weight with unported heads and a hydraulic camshaft.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 10 sec small block 340's [Re: B3422W5] #1465722
07/10/13 01:01 PM
07/10/13 01:01 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I have a stock stroke .030 360 in my car, and have gone 10.56. It's nothing special, kb 107s, .525 solid cam, mild ported eddys, m1 intake and 850 alcohol QF carb. It has a 9" J converter, 727 w/transbrake, and 4.30 rear gear with 29" tires.
Re: 10 sec small block 340's [Re: moparguy7074] #1465723
07/10/13 01:12 PM
07/10/13 01:12 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
From what I've learned w/ my 340;
Torque is the name of the game and a stock stroke 340 doesn't make much down low, so you have to spin it, and of course to spin it you need spring pressure and a cam that works in that rpm range( Im gonna say upwards of 8000 rpm)
If I had to use a stock stroke in a 340 to run 10sec., I'd use a solid roller cam, but still consider a solid flat tappet. Cam timing is everything.
Yeah, it's got a smallblock.
Re: 10 sec small block 340's [Re: 340B5] #1465724
07/10/13 01:18 PM
07/10/13 01:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
There is a guy at the local track who had one. 10.70 car
Stock stroke 340, 12-13:1 Ported W2's, big solid roller .700+ lift with 1.6's, 727, 5.13 gears and 29.5" tall slick.
He built a 418 short block for it, changed the gear ratio and the car goes 10.teens now.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 10 sec small block 340's [Re: justinp61] #1465725
07/10/13 01:30 PM
07/10/13 01:30 PM
BPE Offline
BPE  Offline
I honestly don't remember, it seems like it was 26 something, but I can't say for sure. For what it's worth the car ran the following year with less comp. (9 something to 1) and 1.88 valve stock heads and went 9.83 in the first 5 passes. He hasn't had it out since.
Rod
Re: 10 sec small block 340's [Re: Triple Threat] #1465726
07/10/13 01:31 PM
07/10/13 01:31 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Buddy of mine has a stock stroke 340, pump gas, Eddy Heads, around a .550 hydraulic roller (can't remember exact), 4.88 gear, 31" tire, 4500 stall, and has gone 8.80's. N/A
Re: 10 sec small block 340's [Re: TheOtherDodge] #1465727
07/10/13 02:23 PM
07/10/13 02:23 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Dragster?
Re: 10 sec small block 340's [Re: 340_Dart] #1465728
07/10/13 02:39 PM
07/10/13 02:39 PM
Renton Washington
Renton Washington
Dragster?
Must be, thats about right, for a 500HP combo to trap 150mph @1800 pounds.
-Dustin
Re: 10 sec small block 340's [Re: 340_Dart] #1465729
07/10/13 04:31 PM
07/10/13 04:31 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Dragster?
Soft 1/8th mile ?
Re: 10 sec small block 340's [Re: moparguy7074] #1465730
07/10/13 04:43 PM
07/10/13 04:43 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Sounds like a strong runner. What cam is it? Any head flow specs?
Re: 10 sec small block 340's [Re: tubtar] #1465731
07/10/13 06:09 PM
07/10/13 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dragster?
Soft 1/8th mile ?
Thats my opinion.. to run 8.80s in the 1/4 with a
4.88 gear its gonna have to turn well above what a
hyd roller will go to.... JMO
Re: 10 sec small block 340's [Re: TheOtherDodge] #1465732
07/10/13 08:29 PM
07/10/13 08:29 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
fogger + a plate under each carb for a total of 950 hp at the wheels and I think he was on a street tire
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
