93 Cummins Leak
#1465585
07/09/13 08:23 PM
07/09/13 08:23 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Finally got some time to work on mu Cummins. I shot some air into the fuel line from back at the tank. I appears that the plug in for the fuel heater is leaking. I can't see how to remove the part. Is it the entire base that has to come off? I tried taking a pic with my phone for a better look. No go. Thanks in advance ![](/ubbthreads/images/graemlins/bow.gif)
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 93 Cummins Leak
[Re: herkamer]
#1465590
07/10/13 02:27 PM
07/10/13 02:27 PM
Rug_Trucker
The video said there was a 13/16th nut up there. That was a '94. I have no nut that I can see. There is an adapter with a slot running across it. I am trying to either pry the plastic heater off, or see it that adapter is holding in in there. Aggrivating durn thing! Back to the 90+ heat and humidity! Thanks Herkamer!
Re: 93 Cummins Leak
[Re: Rug_Trucker]
#1465591
07/10/13 03:21 PM
07/10/13 03:21 PM
Rug_Trucker
Of to the hardware store with an old filter. I have to get 2 NPT nuts to work against each other to remove the adapter.
Re: 93 Cummins Leak
[Re: Rug_Trucker]
#1465592
07/10/13 03:43 PM
07/10/13 03:43 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
No prob! ![](/ubbthreads/images/graemlins/thumbs.gif) If you need additional pages, I can snap pics of those as well
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
Re: 93 Cummins Leak
[Re: Rug_Trucker]
#1465594
07/10/13 11:59 PM
07/10/13 11:59 PM
Rug_Trucker
94's might be held on with a hex head. 93's no way. Looks like I will need to get a grade 8 washer and grind it flat to remove the adapter pipe.
I ordered a shorter heater eliminator pipe from Cummins. It may be in tomorrow or Friday.
I have time to reinstall the tank. I'll have to get some pics up when I get the fitting out.
Re: 93 Cummins Leak
[Re: Rug_Trucker]
#1465597
07/15/13 06:54 PM
07/15/13 06:54 PM
Rug_Trucker
Yipeeeee! There is some rattlin' going on out in the driveway! The new piece can be installed with an 8mm or a sloppy 5/16th hex wrench. ![](/ubbthreads/images/graemlins/drive.gif)
