Anyone know what this Oil Analysis means or reads?? #1465447
07/09/13 02:38 PM
07/09/13 02:38 PM
N.E. OHIO, USA
A12 Online content OP
A12  Online Content OP
N.E. OHIO, USA
Had this sent to me by someone that was concerned about the condition of his engine oil that appeared "darker" than normal so he took it to a local "Oil Analysis" company. To me the oil seemed normal and the chart doesn't say that there is anything wrong with the oil just that this is what was found. This person thinks there is something major wrong and that there is some kind of engine damage as a result of the condition of the oil.
This is what the OA company wrote to him.....
We observed nonferrous metal debris consistent with copper and aluminum. These are identified by color, and alignment in the magnetic field. Because copper and aluminum are nonmagnetic, the wear particles disperse throughout the slide in no particular behavior pattern. Iron, on the other hand aligns itself with the magnetic field of the test apparatus in strings of ferrous debris. I have attached a brief description of the test conditions for identifying nonferrous metal debris.
Re: Anyone know what this Oil Analysis means or reads?? [Re: A12] #1465448
07/09/13 02:50 PM
07/09/13 02:50 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
It seems like the company that did the analysis simply places the oil sample in a magnetic field under a microscope and sees which particles align themselves with the field (iron particles, likely from the block) and which particles don't align themselves with the field (copper and other non-ferrous metals, likely from bearings). I guess it would let the guy know if his cylinder walls being worn or if the bearings are getting worn.
Either way, this seems like a really cheesy, low-tech way of analyzing oil. Most places use mass spectroscopy. X-ray fluorescence could also tell you what's in the oil (but maybe not quantitatively). IMHO, NAA is the best way to analyze oil samples: https://board.moparts.org/ubbthreads/show...rt=all&vc=1
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Anyone know what this Oil Analysis means or reads?? [Re: 1968RR] #1465449
07/09/13 03:06 PM
07/09/13 03:06 PM
dogdays Offline
dogdays  Offline
First, it's a crap oil analysis. Don't use them again.
Second, copper and aluminum are bearing wear metals. But as its a crap oil analysis, it has no meaning. Run the engine with its new oil for 5000 miles and send THAT oil into a good lab. Titan and Blackstone are two I have used, there are many more.
They should check for viscosity, particulate in the ranges usually used in oil analysis, then some sort of spectral analysis that tells the ppm of different elements.
Shouldn't cost more than $25 to get all of this, possibly less.
R.
PS: Lubrication is one of my work areas.
Re: Anyone know what this Oil Analysis means or reads?? [Re: dogdays] #1465450
07/09/13 04:58 PM
07/09/13 04:58 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
I used to know a guy who hauled for Haulmark trailer ... lived near me in down-state MI ... he also said that many of these oil analysis deals are a scam.
Re: Anyone know what this Oil Analysis means or reads?? [Re: dogdays] #1465451
07/10/13 05:15 AM
07/10/13 05:15 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
R.
I agree that is a pretty lousy 'analysis', nothing like I've ever seen.
All about the PPM and/or the identification of outside contaminants.
I can't afford this. mark
Re: Anyone know what this Oil Analysis means or reads?? [Re: a12superbee] #1465452
07/10/13 08:18 AM
07/10/13 08:18 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
R.
One that I had done,this one makes sense !
Re: Anyone know what this Oil Analysis means or reads?? [Re: A12] #1465453
07/10/13 12:52 PM
07/10/13 12:52 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
If you're getting analysis done, I suggest none other than POLARIS Laboratories.
POLARIS Laboratories is one of the largest in the nation with four locations and has attained the highest level of ISO accreditation, the ISO 17025 A2LA . I use their private label program through - Oil Analyzers Inc
Examples of other POLARIS Laboratories Private Label Programs includes but is not limited to New Holland, Chevron, Kendall Motor Oil, ConocoPhillips, Allison Transmission, Case Construction and many others. Those companies trust POLARIS with their testing needs, so do I.
