Dumbed Down Hemi #146498
11/06/08 02:39 PM
11/06/08 02:39 PM
MA
Greg55_99 Offline OP
MA
I came across this engine on Craigs list a little while ago and the distributor caught my eye. It's an HEI from some application, I don't know what. Can anyone identify it? I don’t think this is the Arrington Engines conversion. It's on the drivers side.
Any ideas? I like the concept of a dual quad Hemi with no computer.
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146499
11/18/08 01:22 PM
11/18/08 01:22 PM
MA
MA
Finally got an answer from the gent that put this together:
"HI I am the builder of the HEI conversion, thanks to GREG55 66 for the heads up to this site! I have built and run quite a few of these conversions without any problems, I do use a MSD HEI coil and have found no noticeable diffrence from single plug wires to the 1 to 2 split wires, the hemi does have it's limits though! 6000+ rpm without an upgraded dampner pulley is not recomended, I have been selling the complete engines with this conversion and now with all the response I have recieved I may sell a conversion kit, for more pics and info check out hubgarage.com under Woody's garage. thanks for the intrest and always glad to help.
1. I had no idea there were diffrent timing covers for the cars or trucks, I get them from mopar as (5.7 timing cover)
2. when I do these there will be no need to send me any parts for mod, all new mopar
3.yes all parts will come in the conversion kit, aluminum timing cover, timing set, cam gear, distributor, msd coil, belt, sensor plugs, flex plate for use with 727, (single or dual quad intake and wires as required)
4. most of the conversions I have done have been single carb and they haul [Edited by Moparts - Keep it clean]! I have not run the dual quads because I sold my test ride the Woody1 dodge H1 before I got to use the dual quad manifolds
5. yes I have run the comp cams with great results, when ever I use an upgraged cam and higher rpm I recomend an aftermarket damper pulley ALWAYS! I have seen many factory engines with stock dampers, big cams and large holes in the side of the block! almost always the crank timing ring lets go taking a rod with it,
6. I am putting together package pricing and will let you know soon.
I hope that helps talk soon
Woody"
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146500
11/18/08 01:23 PM
11/18/08 01:23 PM
MA
MA
Closer
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146501
11/18/08 01:38 PM
11/18/08 01:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure is weird seeing a small block with a distributor on the front, AND on the right hand side
Cool deal though!
Re: Dumbed Down Hemi [Re: ScottSmith_Harms] #146502
11/18/08 01:41 PM
11/18/08 01:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, I fixed it
Now....What can we do about that alternator.......
Re: Dumbed Down Hemi [Re: ScottSmith_Harms] #146503
11/18/08 02:00 PM
11/18/08 02:00 PM
MA
MA
Few more.
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146504
11/18/08 02:02 PM
11/18/08 02:02 PM
MA
MA
I like the concept.
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146505
11/18/08 02:47 PM
11/18/08 02:47 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I don't like that big ole HEI cap on there.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Dumbed Down Hemi [Re: Greg55_99] #146506
11/18/08 08:38 PM
11/18/08 08:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks fine to me so far. I'd really like to see the distributor drive setup before judging one way or the other though.
Can you ask Woody to join up and put a post up somewhere with prices? I think I'm not the only one who wants to see the business end of it.
Re: Dumbed Down Hemi [Re: ZIPPY] #146507
11/18/08 10:24 PM
11/18/08 10:24 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Hi Greg. Can I ask how you are terminating both wires into the termianl ? Looks pretty trick. I have a customer looking to do the dual wires per each distributor lead. We have some pretty trick 5.7/6.1 boots. Here are some pics. I like what you are doing.. Out of the box thinking. Thanks for joining Moparts, welcome.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Dumbed Down Hemi [Re: sunroofgtx] #146508
11/20/08 06:54 PM
11/20/08 06:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Bump....
C'mon now, out with the info.
Alot of guys want to buy a setup like that.
Details man! Details!
Re: Dumbed Down Hemi [Re: ZIPPY] #146509
11/20/08 11:31 PM
11/20/08 11:31 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
6.1 hemi also?
Spill it......?>
Re: Dumbed Down Hemi [Re: hemibeep] #146510
11/21/08 12:06 PM
11/21/08 12:06 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Re: Dumbed Down Hemi [Re: ZIPPY] #146511
11/21/08 12:36 PM
11/21/08 12:36 PM
MA
MA
I forwarded the link to Woody, the gent that does this. I'm hoping he'll get on.
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146512
03/28/09 12:30 AM
03/28/09 12:30 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
is this set up the one from arrington engines ?
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Dumbed Down Hemi [Re: fstfish66] #146513
03/28/09 12:32 AM
03/28/09 12:32 AM
MA
MA
Nope, that's a Woody special.
Drop him a line for details:
rkwprobuilt "at" yahoo.com
Greg
Re: Dumbed Down Hemi [Re: Greg55_99] #146514
03/29/09 08:37 PM
03/29/09 08:37 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Its not too big of a deal....just have to know what gear to bolt onto the end of the cam to drive the distributor.
TR Waters
Re: Dumbed Down Hemi [Re: TrWaters] #146515
10/01/09 09:22 AM
10/01/09 09:22 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Any hints?
It looks pretty similar to an RB distributor gear, but wider.
Do we need to chop the gear off an old RB cam?
Re: Dumbed Down Hemi [Re: ZIPPY] #146516
10/01/09 09:31 AM
10/01/09 09:31 AM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
I wonder how much that kit costs...
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Dumbed Down Hemi [Re: maundmotorworks] #146517
11/22/09 10:47 PM
11/22/09 10:47 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
Nobody has heard what this kit cost yet have they?
www.sikosracing.net Heads up Drag racing
