'69 B Body Trans Crossmember #1465045
07/08/13 09:56 PM
07/08/13 09:56 PM
SE VA
hemibee69 Offline OP
SE VA
My 69 Super bee is a 4 speed the 69 trans is long gone, the trans in it is a '70 with the newer style transmission mount (like the Auto). What crossmember can I use, A 69 B body auto crossmember or a 70 or later crossmember.I think the Auto and manual crossmembers were the same 1970 and later.
Until I got this B Body I thought all man and auto crossmembers were the same, like the E bodies. Will an E body crossmember work in a '69 B body with a 70 type man transmission?
thanks in advance
JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: '69 B Body Trans Crossmember [Re: hemibee69] #1465046
07/08/13 11:20 PM
07/08/13 11:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
For a 70 Tailshaft B/E 4 speed you would use a 66-69 AUTO trans crossmember , the 70 will require you to drill out the holes that for the 4 bolts that hold it to the torsion bar crossmember as the 66-69 used a larger diameter bolt.
Re: '69 B Body Trans Crossmember [Re: JohnRR] #1465047
07/10/13 08:57 AM
07/10/13 08:57 AM
SE VA
SE VA
Thanks for the reply, are the E and B body crossmembers interchangeable?
JiK
Re: '69 B Body Trans Crossmember [Re: hemibee69] #1465048
07/10/13 10:14 AM
07/10/13 10:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
JiK
I have no idea , 71 up I would go out on a limb and say yes , but prior
Re: '69 B Body Trans Crossmember [Re: JohnRR] #1465049
07/10/13 10:40 AM
07/10/13 10:40 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Go to Brewers website ... they have photos and details of every crossmember made!
